1st Gen R52 S Mini Ignition Key Programming
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by cockney, May 14, 2019.
  1. cockney
    cockney New Member
    Oct 5, 2011
    16
    Have 2007 1st gen MCS convertible, need new ignition key but also need the programming instructions.
    Have attached pic of key, but it does not show here
  2. wmwny
    4,040
    2,242
    Welcome to M/A!
    Your MINI dealer can set your key up for you.
  3. MCS02
    Welcome to MA! Like wmwny said The only way I know is to have the dealer do it. but there may be another way.
  4. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    These are all the methods I know to reprogram a key:
    The remote control portion of the key can be programmed without any software. Here are the instructions:
    Method 1:
    Working from within the vehicle and with the doors shut:
    • Turn ignition to position 1 and back to off within 5 seconds.
    • Remove the key from ignition and press and hold the unlock button for 15 seconds. During this time press the key lock button 3 times within 5 seconds.
    • Release both buttons.
    • Doors will lock and unlock to show correct programming has occurred.
    Method 2:
    For this procedure, you need to have one working key and another key that needs to be programmed.
    • Get in and close all doors.
    • Turn on the ignition and turn off quickly (no more than 5 seconds). Next action must take place within 30 seconds.
    • Remove the 1st key.
    • Hold the key up near your left shoulder (so it is closer to the remote receiver antenna).
    • Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
    • Quickly repeat steps 4 & 5 for key #2 etc.
    If it does not work, try doing the keys in the opposite order. Key 2 then key 1, vs 1 then 2.
    Method 3:
    Alternate if you do not have a working remote:
    • Turn key to position 1 five times very quickly.
    • Remove key.
    • Hold the unlock button, then press the lock button 3 times. Release the unlock button.
    • If you have another key, perform the same button-pressing sequence within 30 seconds.
    • Turn on ignition to finalize.
  5. MCS02
    Excellent. If you don’t mind this would make a great how to article. I can give you a link where to put it.
  6. Canusrufis
    210
    107
    Winston Salem NC
    Sure.
  7. MCS02
  8. Canusrufis
    210
    107
    Winston Salem NC
    Published! Thanks for the link
  9. MCS02
    Thanks!
