I bet Mark has got a story to tell with that 5th wheel he has in tow behind his MINI :ihih: That trailer looks like a lot of fun for two people What's the gas milage like?
DUDE, I WANT ONE OF THOSE!!!!! Mark, did you make it yourself? If it's has to do with metal, I can usually make it. Throw in wood and I'm done..... LOL. If you made it, would you consider making another? Let me know. Mark
Mark, you're not going to be able to do 150 with a trailer in tow I must say that trailer looks sharp
Don't kid yourself.... I drag raced a guy in a camming mustang with my S10. It's obvious I would have beat him but you should have seen the look on his girlfriend's face when I pulled on him and she saw I was pulling a trailer with (2) 700lb jetskis on it. It was priceless. Mark
On the track of course.... [ame="http://www.youtube.com/watch?v=JYFd10yOq04"]YouTube - Figure 8 Trailer Race at Raceway Park, MN sep 27 2008[/ame]
I did not build the trailer, this fellow did;[email protected] Joe lives just north of Indianapolis, where he custom builds them, and he also builds them on spec. and sells them on ebay. They ride on a square tube frame, with a torsion bar suspension. He uses alloy wheels, with radial tires, not regular trailer tires/wheels. It follows the Clubman so well it's easy to forget it's back there. The cabin is made out of Birch plywood, covered in your color choice of aluminum. Ours is a light pewter color (gray). He uses vinyl flooring, and solid oak cabinets. The trailer weighs 600 lbs. with a tongue weight of only 80 lbs. So the rear of the Clubman does not ride any lower in the back. I figure fully loaded with gear/food/clothes/bedding, we may add another 150 lbs or so, with most of that in the rear, or over the axle, so tongue weight should not ever go over 100 lbs. Some other amenities include a 110/12 volt electric system, with a marine deep cycle battery/built in charger. There are 2 reading lamps inside, along with a 110 and 12 volt plug-ins, the roof vent has a built in fan. There is a light over each door, plus a light in the rear hatch to light the galley, and plugs over the counter top. All the woodwork has 3 coats of polyurethane, and the underside is sprayed with an automotive undercoating. Mark
Because MeRV is a home built trailer, with no title or VIN# I have to get him inspected before I can get a license plate for him. At least that is what you need to do here in Missouri. Mark
