1st Gen R53 Cooper S Mini out of commission.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Tummi_Gummi, Feb 11, 2017.
  1. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    [​IMG][​IMG][​IMG][​IMG]
    Sent from my Pixel using Tapatalk
    Lights look good!
  3. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Looks good, I'd advise ditching that coil pack for an oem one.
  5. 00Mini
    It's always nice to see the pieces parts going back in !!
  6. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    [​IMG][​IMG]
    Well pieces are back :)
  7. 00Mini
    Have you fired her up ??
  8. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    No. Shop accidently bent oil squirter. Luckily I saw it before putting the pan on. That's why it is off in that picture.
  9. MCS02
    Looks great! I had Alta boots on my intercooler they leaked so keep an eye on them.
  10. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    Cars alive. However I had a bad exhaust leak so I got that fixed. Installed a Bosch o2 sensor. Big mistake, car couldn't get a reading most of the time no reading. Had a short in the oem sensor related to the needing exhaust work and the leaks at the flanges. So I fixed the OEM sensors wiring and have it back in. Thought my loud ticking was my exhaust leak turns out I don't have any more. It did get quieter after the leaks were gone but I pulled my valve cover and had to remove my rocker arms. Found cylinder 1 had failed rocker assembly. Both lifters on it were dead. No pressure. So they had a gap between the valves and the caps.
