2nd Gen R56 Cooper S MINI teardrop?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Rixter, Jul 19, 2010.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    #1 Rixter, Jul 19, 2010
    The day after driving home from a BBQ (having driven very spiritedly along the highway for about 1/2 an hour) I noticed this strange treardrop running down the driver's side wheel arch. I check under the hood and nothing obvious. Nothing from down below either. It was also bone dry on the roads.
    Has anybody ever had this before or have a clue what could've caused it?
    The first photo is with the bonnet closed, the second with the bonnet lifted.
  2. Minidave
    What year is your car?
    The 1st gen cars had their headlight washer/windshield washer bottle right there - cap could be loose or off.
  3. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    2008 MCS R56
  4. Metalman
    Are you sure your MINI didn't into some of that BBQ sauce?
    Possibly cosmoline leaking out with the high temperatures.
    Is it oily? or water? Did you use you washers? Leaking washer hose?
  5. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    No BBQ sauce or windshield washer used. When I wiped it off it wasn't greasy or colored and it didn't leave a stain on the wheel arch.
  6. lotsie
    stagehand/part time detailer
    Right here
    I have heard of cosmoline leaking in that area onto the arches. You were probably lucky and got it off before it stained. I know a couple of folks who had arches changed under warranty when it happened.
    You may need some Cosmonot from Prima.
    Mark
  7. miniconcarne
    miniconcarne New Member
    38
    Machinist
    Home
    Cosmoline. All the holes, in the underside of the bonnet, are coated inside.
    Noticed this on a 2010 S last weekend.
  8. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Mark
    But for the Cosmonot to work I would need to find the source and wipe it clean, correct?
    Bryan
    Thanks for the confirmation. Still sporting my first mod from you :Thumbsup:
  9. lotsie
    Right here
    Yes, that would be best, but it will also clean any that did seep out.
    Mark
