Entertainment Electronics 2nd Gen MINI Voice Command and Phone Buttons
Discussion in 'Tuning and Performance' started by gaparker1, Sep 11, 2011.
  1. gaparker1
    gaparker1 New Member
    Sep 11, 2011
    Rhode Island
    Just bought a 2007 MINI and loving it. On the wheel there are buttons for voice commands and telephone. On the radio there is also a telephone button. Problem is the radio does not display the radio option. Why the buttons if the option is not there??
  2. Jafar
    Jafar New Member
    Sep 1, 2011
    188
    14
    Mfg. Technical Specialist
    Murfreesboro, TN
    There is a bluetooth module available from MINI USA. If you decided to get the module, as an add on, you do not have to buy a new steering wheel. :wink:
    BTW - welcome to MA!
  3. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    695
    Go aftermarket
    You can still use the buttons on the steering wheel without having the factory module which is way way to expensive.
    I added a parrot bluetooth interface to my 05 cooper and a custom wire harness that is plug-n-play to the radio headunit.
    First figure out what features you want. I use an iphone and I wanted to be able to answer and hang up plus use voice dial commands. I did not care to have the caller id function on the bluetooth unit or the radio headunit. I decided on this unit from amazon.com [ame="http://www.amazon.com/Parrot-Evolution-Bluetooth-Car-Kit/dp/B000A0BQJO/ref=sr_1_4?ie=UTF8&qid=1315781545&sr=8-4"]Amazon.com: Parrot Evolution Bluetooth Car Kit: Cell Phones & [email protected]@[email protected]@http://ecx.images-amazon.com/images/I/[email protected]@[email protected]@31Gvf9P2WLL[/ame]
    Then I contacted Mikey at Newministuff.com
    Mikey creates custom wire connections that hook from the radio unit to the bluetooth unit. Took about 20 minutes or so to install. Real easy. You pay more for the harness than the parrot unit given the exchange rate. If you have any questions on which specific cable to order from them, send an email. They will get back to you in a few days or so.
  4. Justa Jim
    I have the exact same set up, but I ordered both EVO and harness from Mikey. On the 2nd Gen cars, you have to take the entire dash apart to install it, so longer then 20 minutes is required. Easy to follow instructions are included, so it was not a problem.
