The following is a list of items I have left over from the parting out of a 1st Generation MINI Cooper S, what is listed is all that I have left. All prices DO NOT INCLUDE SHIPPING, but I will combine shipping if you are getting more than one item. Prices are not set in stone, so if there is something that you want, you can always make an offer, worst I can say is no. Brake Booster w/ Vacuum Check Valve, Fluid Res, Cap and Line $65.oo Overhead Clock 2002-2004 model years $15.oo Crono / Nav Gauge Cluster $90.oo ECU/DME from 2006 MCS $150.oo (firm on Price) Knee Bolster (goes below steering wheel) $35.oo A/C Fan Assembly $30.oo Intercooler Clamps $8.oo each (1) Larger and (2) Small left ABS Control module and pump Assembly $65.oo Cowl $60.oo Driver Side Fender $35.oo Upper Dash Section / Dash Pad $85.oo Passenger Side Washer Fluid Res with Pump and Hoses $30.oo Driver Side interior Fuse/relay panel $40.oo Rear Section of Air Box Cover $20.oo Clutch Slave Cylinder $15.oo DME/ECU Cover $8.oo Gas Cap with tether $10.oo Sun Roof sun shades Front and Rear $35.oo for the pair Sun Roof Motor $35.oo Rear Tail Lights - Pre face lift (very minor fading) $60.oo Front Brake Calipers w/ Pads, Wear Sensor and Carriers $60.oo Struts and Springs, Used and showing wear but useable $100.oo (would be good for someone that installed after market Coilover etc and wants to return to stock. DomeLight Assembly (working with Buttons) 20.oo$ Drivers Side Mirror (NO MIRROR CAP) Heated - $30.oo Gas Door Locking Actuator $15.oo Parking Headlight Control Stalk - $25.oo Parking Distance Control Box $35.oo Passenger Seat / Side Airbag $40.oo Starter Assembly $50.oo TMAP sensor $15.oo Turn Signal Control Stalk $25.oo Yaw Sensor $60.oo Fuel Pressure Regulator for the Cooper S $5.oo Passenger Side interior Door Handle $10.oo
