More upgrades for Boogie
Discussion in 'Classic Mini' started by yellowbritishrocket, Feb 1, 2016.
  1. Minidave
    I always use a tie rod/ball joint tool to get mine loose, the joint is a taper, so they always stick - you actually kinda want them too, so they don't turn and ruin the hole.....
    Glad you got it all done! Well, at least the one side...
    Most people find they have to remove the upper control arm to get the rubber out, that's why I'm going to coilovers on my next Mini.....they're spendy but adjustable and easy to change.
  2. yellowbritishrocket
    May 16, 2009
    618
    277
    id love to switch to coilovers...but for now I have hilo's with Mini Spares red dot cones and bilstein shocks
  3. Minidave
    Yeah, I ran hilo's and med stiffness coil springs on Buzz, you couldn't get the coil springs in/out without removing the upper control arm either....
  4. yellowbritishrocket
    May 16, 2009
    618
    277
    what would be the easiest way? undo one side of the bolt and slide it out?
  5. yellowbritishrocket
    May 16, 2009
    618
    277
    over the weekend i got the passenger side CV/Pot Joint boots done! the passenger side cv joint gave me a bit of a fuss but i was able to get it done! i swapped out the zip ties that come with the kits for some ACT cobra low profile zip ties... worked like a champ!
    but yesterday and today brought some more parts for boogie!
    a nice wood steering wheel with polished metal spokes
    An aluminum billet cup holder from Specialist Components UK
    and the big piece... and new Stainless Steel manifold from Specialist Components...
  6. 00Mini
    Steering wheel is killer !!
  7. Minidave
    Where do you get those cable ties? I'd like to get some.....
    Did you get the spring rubbers out OK?
  8. yellowbritishrocket
    May 16, 2009
    618
    277
    here is where i got them
    Amazon.com: Low Profile Cable Ties 14-1/2" Black 1 Pcs. Made in USA: Home Improvement
    i havent attempted the spring rubbers yet... ive be spraying the bolts on the upper arm with PB bolt breaker for the last few days hoping to loosen up one side so i can undo the thrust plate on the other and just slide the bolt out
  9. yellowbritishrocket
    May 16, 2009
    618
    277
    and it was 80 british pounds shipped to the states
  10. Firebro17
    Wished I'd've known you were looking for a wheel Roger. I've got one just like it that I'd've sent your way...
  11. MCS02
    I'm looking for a yellow classic.:D
  12. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    I love the wheel too. Very nice. Looks like a Moto-Lita or Les Leston.
    Stainless LCB headers? I didn't even know they existed.
  13. yellowbritishrocket
    May 16, 2009
    618
    277
  14. yellowbritishrocket
    May 16, 2009
    618
    277
    Got the steering wheel in tonight!
    took some persuasion with a mallet to get the old wheel out but i was successful
    12381218_10156705669170790_215588761_o_zpshav5rtis.jpg 12675264_10156705669075790_1962786612_o_zps5fdoskkq.jpg 12874146_10156705623115790_938718683_o_zpstx7wxpfp.jpg
  15. BruceK
    Feb 24, 2015
    Texas
  16. yellowbritishrocket
    May 16, 2009
    618
    277
    And only 45£ for shipping to the states
  17. 00Mini
    Steering wheel really looks great !! :Thumbsup:
  18. yellowbritishrocket
    May 16, 2009
    618
    277
    im hoping to get the manifold fitted tomorrow... i play to use some DEI titanium exhaust wrap on it...keep the temps down
  19. yellowbritishrocket
    May 16, 2009
    618
    277
    The switch panel is built!
    received_1090502901011871_zpsqpgb6mfl.jpeg received_1090513017677526_zps06rg29vg.jpeg
  20. 00Mini
    Switch panel looks nice. Are the lights able to be dimmed ??
