1st Gen R53 Cooper S Morning Hard Starts & Now, 1-3k RPM Hesitation/Yoyo/Hiccup
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minsanity, Sep 11, 2012.
  1. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Update:
    What happened to me yesterday might have just explained half my issues. The hesitation might be a solved mystery.
    Took the MINI to work yesterday. Car started the usual w/ a few tries, drove fine w/ very faint hint of hesitation...must be a good day, me thinkin'. I usually run A/C to kick the highspeed fan on since my lo-speed resistor hasn't been resurrected yet.
    Suddenly, I lost A/C cold air, hmmm, batt light on, another hmmm. Scangauge reads 11+v. Switched A/C off, batt light goes off w/ it, Scangauage reads 12+v instead of the usual norm of 13-14+v. Did it 3x more, same results. CRANK PULLEY. Gotta get myself home quick & weave thru city traffic, I thought. Got home w/ temp gauge @ usual midpoint but scangauge read 234F/112C, exact temp trigger for the high speed fan. Engine bay emitted a very very light haze w/ a rubbery smell. Confirmed w/ Keith my suspicion before digging into it. Glad I had a crank pulley puller ready. This is when forum-generated paranoia becomes a good thing.:)
    Attached pic shows a totally separated damper. Miraculously, my newly installed OEM belt,stock idler/alternator/A/C pulleys & tensioner were all unscathed. I'm blessed. It somehow cushioned the blow of frustration on why this car suddenly decided it wants to get sick.:confused5:
    I'm looking at the bright side always. I'll be doing all these repairs & maintenance at 1 time to get it back better, more enjoyable. These unplanned expenses are like Pacquiao blows! Painful, frustrating, takes the air out of you. Fortunately, I've patience to rope-a-dope w/ an old reliable RAV filling in as my daily.
    Thanks to M/A & the kind members of this community for being my shot of anesthesia!:Thumbsup: I'll keep posted on the healing process!:wink:
  2. Metalman
    Glad to hear the mystery is being solved. It can be frustrating....
    Soooooo, that wasn't one of those BMW "Lifetime" parts?
  3. minsanity
    Sep 11, 2009
    581
    352
    Haha. How many are those they say? CVT, Fuel filter,PS, S/C, Tranny/charger/PS fluids,& so on. BMW made sure MINI remains truly British.:lol:
  4. BlimeyCabrio
    I've seen a crank pulley like that before, up close and personal.
    That's an awful, awful, awful part IMHO. One of the worst OEM parts on a 1st gen MINI.
    Yeah, the car does really weird and unpredictable things when that pulley starts to fail and is slipping a little, before it totally lets go.
    Glad you found it now and are on the path to a working MINI!
    I agree with keith... it's not "if" it will fail, but "when". Because they'll all fail, if driven enough, IMHO.
  5. minsanity
    Sep 11, 2009
    581
    352
    Yeah, I've been bracing for this since I saw a friend's 05 w/ just 21k mi break. Fixed that w/out a proper puller & t'was hell. Learned from it. What damper do you guys have on?
  6. Nathan
    I use the ATI. There are other solutions too.
  7. minsanity
    Sep 11, 2009
    581
    352
    Seems to be the most popular choice. How many miles on it, Nathan? I'd like to believe those should be a real "Lifetime Part". Prior to damper failure, I noticed some significant drop in mpg on the OBC. I presumed t'was due to a lot of stationary idling while observing the engine's behavior on varying rev ranges. I definitely was never running rich. Anyone observed the same?
  8. BThayer23
    Agree. Second place goes to the hydraulic motor mount; though the motor mount is much messier, the crank pulley failure can leave you stranded.
    I have an ATI. Unless you're racing, you won't drive the car hard enough to explore the differences between the ATI and the PRI fluid dampener.
  9. Nathan
    I'm not a good one to ask about how long...I don't drive much. In the year or so it's been on my car I don't think I've covered 10K miles.
  10. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    The Super Damper is elastomer based, like OEM. Elastomers loose their resilience over time due to ozone oxidation (avoid parking next to large electrical motors) and heat exposure (the twisting function of an elastomer generates heat + conductive heat from the crankshaft + convective heat from the operating environment). The good news is, if elastomer performance in a Super Damper degrades or an elastomer fails, the damper will not separate like the OEM damper. A street driver in a cool climate will experience longer optimum performance from the ATI Super Damper, than a car driven at high rpm in a hot environment. Estimated optimum service life is about ten years for a street driven car in warm climates. The elastomers are relatively easy to service with the pulley shell on the vehicle, so at least complete removal is not required.
    Fluid filled dampers also experience damping degradation over time + heat; they are not a "your lifetime" part either.
  11. Dave.0
    I have a ATI Damper and its better made than the OEM.
    If you want a Lifetime Crank Pully get an Soild Crank Pully. :lol::lol:
    I AM KIDDING!
    They will last a lifetime, but whatever it is attached too will suffer a slow non harmonic dampered death. ((Bearings)) :devil:
    Crank Pully Dampers are cheap Vs Motor rebuilds......Just Saying
    Dont use a solid damper.
  12. minsanity
    Sep 11, 2009
    581
    352
    Haha. Was never enticed to put on those solid ones. Cost-wise, they're tempting, but I plan to keep the car & maybe hand it over generations down.:wink:
    Some good insights there, Keith.
    Thanks all!:Thumbsup:
  13. Nathan
    Is that an oxymoron?
  14. minsanity
    Sep 11, 2009
    581
    352
    solid damper
    :DI'd probably go for that!
  15. minsanity
    Sep 11, 2009
    581
    352
    Hi guys, sorry,it has been awhile. Work & travel cut the momentum. Here's a premature update- Finally put on the ATI damper an hour ago. Have yet to take it for a spin. 2 weeks back, replaced the fuel filter & the torn passenger side inner CV boot that I'd just wrapped w/ rolled, ziptied garbage bag to keep dirt & water off that joint. Amazingly, the bag held on well! As expected, the old filter was black, & the housing had some gunk in. Twas a struggle to unscrew the untouched 10yr old filter housing, still managed to finish in less than an hour. Oh & my battery lost all its juice with the long hibernation. It tested OK, & was recharged.
    Took quite a number of cranks to get it started after sitting for almost a month. It felt fuel-starved. When it finally fired, felt some misfire. Turned off, checked all plug wires, then attempted to restart. Took about 3 tries again to get it fired, idle smooth! Checked the hesitation, less noticeable but still felt it. Got better as car warmed up though. I suspect the hard start issue is still there, will have to observe before digging further. For now, just glad to have all these maintenance, repairs out of the way & to have put it back on its feet. Pump seems to prime well, pressure yet to be checked. Have fuel rail pressure regulator, injector o-rings ready to go in if diagnosis would point there. I'll get back after I take it for spin & maybe a fresh tank of vPower.
    Simply followed all the comprehensive DIY How-tos archived here in M/A. All very helpful! Appreciate all your help & inputs! What would I have done w/o your guidance? Thanks guys!:Thumbsup:
  16. Nathan
    Good to see things are progressing, thanks for the updates.
  17. minsanity
    Sep 11, 2009
    581
    352
    After taking the car for a spin, here are my observations:
    1. Sub 2-3krpm hesitation/yoyo still very evident. It's driveable & bearable but it just isn't normal.
    2. After turning the engine off, restarts are never 1 click regardless of engine temp & pump priming. Usually have a few false starts, falls flat & dies. Every successful crank always results in perfect idle though. The new fuel filter seems to have done no improvement here.
    3. After idling a lot & observing the different rev ranges & behavior in different gears, OBC MPG just hovers around 10ish???? ECU must be adjusting to fuel starvation symtoms?
    In the recent coupla months, the ff maintenance/mods/replacements have been done on car:
    1: Oil change w/ OEM filter & Castrol Edge. Never consumes oil between changes.
    2. New OEM coolant temp sensor. Had 1 around & also to rule out temp error induced start problems.
    3. New belt
    4. New battery
    5. New strut mounts & reinforcement plates
    6. New coolant expansion tank to replace the yellow brown 1.
    7. New plugs
    8. New wires
    9. New fuel filter
    10. New ATI damper
    11. New passenger inner CV boot
    I'm just hoping it's not anywhere near the pump. Too pricey a part in such a short time span! & The filter was such a hassle. I still have to check fuel pressure & have the fuel rail pulse/pressure reg, its o-rings & injector o-rings ready. Will follow what Keith said on the pressure check.
    Keep those ideas coming. Most of done items were maintenance necessary so I never looked at them goin to waste.
    Help still needed at this point.
    Thanks guys!
  18. minsanity
    Sep 11, 2009
    581
    352
    Anyone please point me to where the MAP sensor is & how to clean it? Worth trying? thanks!
  19. minsanity
    Sep 11, 2009
    581
    352
    Ok guys, here's a follow up. With the persistent symptoms, I had to gather enough courage & tools, of course, to get down to fuel rail pressure testing. I was bracing myself for low pressure ( no pun intended, heart & prayers to all of Sandy's victims). Somehow, with all these unrelated issues popping at same time, I'm beginning to think there's some truth to "the Law of Attraction". Unfortunately, I'm attracting all the negatives lately...need to think more of happy motoring than maintenance-needed-next, I guess.
    Anyway, here are the results:
    1. Key at 0: 0psi
    2. Key at 2, pump primes: 22psi then drops back to 0 instantly after pump off
    3. Engine on after a few tries: 22psi across any rpm
    4. A lot of headscratchin!:confused5::confused5::confused5:
    All these & no codes. New rail pulse regulator doesn't hold pressure & 22psi is way low in comparison to Keith's guide. Pump relay was switched w/ headlamp washer one, no effect. The Pump? Uh oh, there's your 'Law of Negative Attraction' proof. That's the 1 I feared most. It's supposedly an R56 thing!:confused5:
    I've never felt such a mixed bag of emotions(thrill, anticipation, disappointment, triumph, frustration,relief, fun & scalp itch. In no particular order) dealing w/ a car. Those emotions are usually reserved for WaGs, right?:wink:
    Anyway, just sharing my 'fun' troubleshootin' adventure. Of course, your thoughts, inputs are all welcome & will be appreciated!
    Oh, by the way, after a day's worth of motorin' struggle dealing w/ hiccups, low end power & constant rev matching, I ended w/ a new issue. Chatter on the passenger side of engine that drowns itself when revving...What the??? Head spins! After gatherin' myself, stethoscoped both sides of the charger 1st. Whew, smooth. RELIEF! Checked the new ATI for wobbling- NONE. Scoped the tensioner, THERE! The strut lost 1 bushing. Ziptied it shut temporarily...SILENCE finally.
    Sorry for the long post. Your turn, guys. Thanks!
  20. ScottinBend
    :popcorn:
    Saving this one for my archives. Great thread.
