I'll get some pic's Commute is about 30 min, 27 mi's one way No OCC I'll start another post as we are close to hijacking this one!
Actually you can use the oem bolts. I tried the ones MM sent but found the washer too big and they split the oem rubbers. So I used a visegrip to hold the oem outter collar and unscrewed the oem bolts, then used correct sized o-rings for the vibration dampers. Everything looks oem except of course the RED MSD Just my 2 cents. Cheers Mr. Jim
My new check list before getting carried away: 1. Which forum is thread in? 2. Is it a justa or an "S" being talked about? 3. Which generations is it? Good article. Jim
