Msfitoy :: 2003 MINI Mini Cooper S
Discussion in 'Member Garages' started by Msfitoy, Jun 3, 2011.
  1. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    Automotive/Industrial Designer
    NC
    Msfitoy :: 2003 MINI Mini Cooper S (2010-12-01 09:07:59)
  2. SilverCarbonFiber
    SilverCarbonFiber New Member
    Jan 16, 2012
    30
    I own a precision CNC mill and lathe/screwmachine
    South San Joaquin, just below the Sierra foothills
    Lot's of mod's, no details?!? Meticulous work.
  3. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    #3 Msfitoy, May 8, 2012
    lol...ok you asked for it...
    MSFITOY! 2003 Mini Cooper S:
    1. Pure silver
    2. Black roof
    3. Powered sunroof
    4. Auto climate
    5. Xenon lamps
    6. Rain sensing wipers
    7. HK premium sound system
    8. Sport suspension
    9. DSC, anti-lock brakes
    10. OEM Navigation
    Exterior modifications:
    1. Black upper Aero grill and lower M7 Ultimate grill
    2. M7 front CF splitter
    3. Carbon Fiber (CF) rear Aero wing
    4. Craft Square CF mirrors
    5. Custom roof/hatch aero management splitters
    6. 35% glass tint, 20% windshield band
    7. Carbon fiber DFIC Ram Intake
    8. Folding two hook
    9. Sonar/Spyder HID/led lamps
    10. JCW brake ducts
    Interior modifications:
    1. Sparco Milano black leather seats
    2. Schroth four-point harnesses
    3. Whalen shift knob
    4. Panavise PDA/IPOD cradle
    5. Auterra OBD-PDA reader
    6. PLX digital A/F meter
    7. Digital boost gauge (0.1psi resolution)
    8. Intercooler IN/OUT digital temperature gauge
    9. Digital Nitrous pressure gauge
    10. Digital Voltage gauge
    11. Digital Exhaust Gas Temperature (EGT) gauge
    12.
    13. Lighted military auxiliary arming switches
    14. Valentine V1 radar detector
    15. Custom gas, brake, clutch and dead pedal
    16. Haletron fire extinguisher
    17. Five panel "Wink" wide angle mirror
    Electrical modifications:
    1. PIAA-X1100 fog beams
    2. 120 watt Extreme White bulbs in factory high beams
    3. XP3 active deer avoidance system
    4. Whalen 100watt electric air-horn/PA system
    5. Full signal L.E.D. bulb conversion
    6. Intelligent brake flasher module
    7. Safe Blitz Sirius XM module
    8. 8mm Jackson Racing plug wires
    9. NGK Iridium spark plugs
    10. MSD ignition coil
    Drive-train modifications:
    Revolution Mini Works +2 ported cylinder head assembly, Schrick cam, over-sized valves
    Alta 15% pulley reduction
    M7 2% crank pulley
    Fidanza 10lb flywheel
    Spec Stage II Kevlar clutch
    Quaife Limited Slip Differential (LSD)
    Rogue Short Shift Kit (SSK)
    PowerFlex urethane motor mounts
    M7 Direct Flow Intercooler (DFIC)
    Mynes Custom tune
    Revolution Mini Works Race header
    M7 oil catch can
    Modified Borla Race exhaust system, Hushmaster II resonator, custom DTM exhaust tips
    Suspension modifications:
    1. Team Dynamics Racing PR-1 twelve spoke 17”x7” satin black wheels
    2. Falken Azenis RT-615, 215/40-17 tires
    3. 5mm spacers
    4. 50mm stud conversion
    5. Front brakes-Red StopTech 380mm slotted floating rotors, 4 piston fixed calipers
    6. Rear brakes-Red coated factory calipers, bronze guides, StopTech slotted rotors
    7. SS sleeved Teflon brake lines
    8. Prospeed GS610 brake fluid
    9. Hsport rear lower adjustable camber links
    10. Alta adjustable heim joint rear sway bar links
    11. Custom adjustable heim joint front sway bar links
    12. Megan adjustable coil-over struts linear rate springs (280 front/350 rear) with integrated front camber plates
    13. Madness 22mm adjustable rear sway bar
    14. M7 front strut brace
    15. M7 Under Strut System (USS)
    16. Front setting negative 2.1 camber, 1/8” total positive toe
    17. Rear setting negative 1.6 camber, zero toe
    18. Longacre scale corner balanced
    [img width=562 height=750]http://www.michiganmini.org/forum/gallery/memberfiles/sIMG_2252.jpg[/img]
    [img width=750 height=331]http://www.northamericanmotoring.com/gallery/data/500/7338small_tsm2.jpg[/img]
    [img width=750 height=497]http://www.mini2.com/galleries/data/500/dtsid09.jpg[/img]
    Didn't get them in time for MOTD2012 but here nonetheless...a pair of suprisingly high quality Sonar/Spyder projection lamps with LED DRL...even has the proper projector cut-off panel so as to not offend peeps who just can't keep their eyes off bright lights...
    Plug/play with H3 for now...but not for long...55w, 6000k HID
  4. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    Been looking at these for a bit, how do you like them? And they don't fit the factory hid right, so what's the kit you got there?
  5. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    Hey Chris...the factory HID are part of the lamp...the pig tail unplugs from it and into the new one...I'll have to splice in the HID components...shouldn't be a big deal...they do look like OEM quality imo...
  6. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    Well, have to talk sometime.
  7. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    And here we go...
    Leftie...
    Rightie...
    Lights!
    :biggrin5: custom aluminum brackets were made to fit under the lamp buckets for mounting the dual ballasts...
  8. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    Love this so much!
  9. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    Thanks! My headlamps were a weak spot for so long...aged...pitted...warped...you name it...:biggrin5:
  10. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    So awesome. I'll hit you up when I need to do mine. ;)
  11. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    Hey Chris...did you put your Mini back together?
  12. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    No... But some day... Sigh
  13. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
    #13 Msfitoy, May 12, 2012
    dayem...that's gotta hurt coming down from a 600whp Mini...:(
  14. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
  15. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
  16. Msfitoy
    Msfitoy Member
    May 16, 2009
    122
    NC
  17. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    That's why i started skydiving. Lol
    I'd just like to have a car again. I'll worry about the build later
  18. ChrisMCS04
    ChrisMCS04 New Member
    May 12, 2009
    92
    14
    I must say Sid has some of the cleanest designing to a MINI...
    And Chris, glad to see you active on here. Hope one day in the future you get the car built back up.
    The two of your cars have been the main inspiration to what is hopefully coming of mine this summer/fall...its been a long time coming with these plans...
