1st Gen R50 Cooper My R50 threw a P1109
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Steve, Nov 27, 2016.
    What does RealOEM call the sensor?
  3. Metalman
    T-MAP measures temperature and absolute pressure...
    MAP only measures absolute pressure...
    Whut would Chad say?
  4. RallyMini370
    are you in a hurry Steve? as I have a few MAP sensors I could send to you when I get back from CR. Also did you check the incoming pipes to the intake and around the MAP sensor? The pipe to the brake booster cracks on the booster.
    Thanks, Chris.
    I'm not in a hurry, yet. Since I hadn't noticed any actual symptoms, I drove the car again to see whether I maybe just hadn't been paying close enough attention. I didn't notice anything plus the CEL went out. So, I decided to clear the codes (primary and pending were both P1109) and see whether they return.
    No new codes yet but I'll keep monitoring. There must be something out of order, though, I just don't know what it is yet. I suspect the sensor but will look at those pipes. Thanks for the advice. :Thumbsup:
