Brakes Wheels 1st Gen Tires Need: 12 X 1.5 Black lug bolts long enough for 5mm spacers
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mini_racer, Feb 23, 2011.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Well, I think the title was quite descriptive. Anyone with any ideas on where to find these?
    Thanks..........
  2. Jan
    Jan Well-Known Member
    377
    382
    turner motorsports has them
  3. mini_racer
    Engr Manager
    Perfect, much appreciated!
  4. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    looking at the Motoring Alliance Sponsor Vendors
    Way Motor Works
    M12x1.5 wheel stud kit - Way Motor Works
    Way Motor Works*::*Search results
    This M12X 1.5 wheel stud kit is great if you hate the stock bolts on your R50,R52, or R53.
    This stud is a straight M12x1.5 stud that will work with 5 and 8mm spacers.
    Made in the USA of premium steel, black oxide finish, bullet nose for easy threading of lug nuts. The wheel studs are 65mm overall length with 52mm protruding from the hub.
    Kit contains 16 studs, enough for 1 MINI.
    Works with 2002-2006 Cooper
    Works with 2002-2006 Cooper S
    Works with 2005-2008 Cabrio
    Works with 2005-2008 Cabrio S
    :Thumbsup:
  5. mini_racer
    Engr Manager
    Thanks, but no thanks..........I was looking for lug bolts, not studs.
  6. BThayer23
  7. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    I know what you mean if they are going to be seen on the wheels. But anything else, this may be some useful reading?
    When comparing the advantages of wheel studs and bolts.......
    Wheel studs
  8. minimark
    If you don't get the black bolts I have a set of silver ones in that size I would sell right.....
  9. agranger
    1,486
    I'm running the Turner studs as well. They sure are proud of 'em at $5/each, but they have held up beautifully for over 4 years with narry a sign of wear (and they are long enough to give Jango a nice Mad-Max look when I'm not running a spacer :D )
  10. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    Lug Bolts are NOT made for frequent removal of the wheels. You can damage the hub. Studs are made for folks that change wheels often. Get over it Terry and get the studs. :ihih:
  11. BThayer23
    :Thumbsup:
  12. mini_racer
    Engr Manager
    Well that was a dose of reality.
    Lynn mentioned studs early on and I was not ready to accept, maybe I am still not ready, but I am getting closer.
    Ok fine fine fine, I will at least quickly research/investigate studs and open end nuts. I damn sure fall into the category of frequent wheel changes.
  13. minimark
    If your a frequent wheel changer and a spacer user the studs are a much better option. Get them and the whole thing becomes a none issue in the future. 2cents
  14. Nathan
    I to am in the studs camp. When changing wheels often they just make sense. The first time you do a swap once the studs are installed you'll be kicking yourself for not doing it sooner. It is SO easy to hang the wheel. No dealign with lining everything up just so and getting two bolts started to get the positioning right. From jack placement to wheels on the ground I do the swap in 15 min total and I'm not the most athletic one out there.
  15. Alan
    Alan Active Member
    98
    Here's what I got:
    I assume these are the TSW studs
    Of course you will need lug nuts, an allen wrench to install them (forget what size), and the special socket for the lug nuts. And I carry a spare stud and nut and socket.
    Also use blue lock tight (sp?) to install and tighten them up good.
  16. mini_racer
    Engr Manager
    I wish I could get a larger pic of those TSW studs, can't really see very much with that thumbnail pic, not that there is much to see anyway.
    Alright, what open end nuts are you guys running?
  17. howsoonisnow1985
    howsoonisnow1985 New Member
    Aug 8, 2009
    171
    Inmate
    Santa Cruz County Jail
    I hated changing wheels, after I installed the studs it became so much more easier to change wheels. I heavily siliconed the TSW spline socket to a 1/2 adaptor which makes it even easier..its just one piece.
  18. Nathan
  19. BThayer23
    #19 BThayer23, Feb 25, 2011
    I like Turner's nuts. They're bigger and hex drive. Studs are your preference. TSW/WMW's are long enough but don't stick out excessively. Turner's have a "bullet nose" that helps to align the wheel without damaging threads, but they definitely stick out some. Oh and Turner's are like 2.5x more $$.
    Turner stud and lug nut on the left, TSW stud and lug nut on the right.
  20. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    These are my TSW lug nuts with a spacer. I did not use the black oxide finish studs that come with the kit because I wanted longer stud length. But I think the silver black combination does not look bad?
    With my wheels they are cover and out of sight anyway.
