R56 Need help 2010 mini cooper s JCW
Discussion in 'Tuning and Performance' started by Justin, Jan 12, 2020.
  1. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Ok thanks for the plug info. Using an obd2 reader. I got an OE thermostat from a secondary supplier.
  2. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    It's electronically controlled thermostat is it not? If it's reading cold how has the car not over heated and blow yet? It would keep the thermostat closed until reaching operating temp
  3. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Anyone know where to get wiring diagrams?
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    A Bentley manual.
  5. Dave.0
    90 C is 194 F which is perfect. It will always get cooler when driving because of airflow.
  6. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    But drop down that much colder? Seems a little on the cold side for driving around
  7. Dave.0
    Yup a cool motor is a happy motor. You never want the motor too warm as it will overheat quickly, blow head gasket and warp head.
  8. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Ya I understand that, but it's called operating temperature for a reason no? Just seems really cold for driving around
  9. MCS02
    @oldbrokenwind said the Manic tune keeps it at 175F. The coldest temperatures you are seeing 68c? If so that’s 155F so your not too far off. Is it running ok?
  10. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Bit of a rough idle now and then, as well as a P1497 code coming up but other than that it's running good
  11. MCS02
    Check the plastic pipe that goes from the intercooler to the intake. I had one get a small crack in it from age.
  12. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    I'll have to look into that, I don't have the stock intercooler
  13. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Hey everyone, just a little update. Temperature is reading good now, and not dropping like mad when I start driving. Like to get everyone's opinion, I'm going to change the oil for the first time since I've had the car, just wondering what everyone uses? Some people say 5w30, 5w40, 0w40,10w60. And then there's the different brands. Just hoping to find out what everyone's had better luck with and with the mods done.
  14. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #74 cristo, Jan 29, 2020
    FWIW, I’m using the new (SN plus) version
    of Pennzoil Platinum Euro 0W-40 (550051113). Good for small gdi turbo engines (LSPI
    prevention), HTHS of 3.6 so a3/b3 rated, and a
    high viscosity index* in the right viscosity range.
    Not many oils hit all those points.
    *and mb-229.5 approval means NOACK is less
    than 10% despite its high VI of 206.
  15. MCS02
    Oh here we go the The Oil Wars!:D Mobil 1 5W-30 every 3000 miles
  16. InstrumentOfPeace
    InstrumentOfPeace Active Member
    Jan 10, 2020
    106
    69
    Penn Plat 0-40 ... hmmm, I’ll have to check for the Euro version now.
  17. DneprDave
    Mobil 1 0W-40 every 5000 miles
  18. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Everyone's different, don't think which to go with
  19. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Do you live in a warm climate all year round? For example, I live in SoCal so I’m not concerned with the first number with the “w” (winter).
    I find my engines run hot as Fck, so unless I have a brand spanking new vehicle, I run 0-40 or 0-50 depending on mileage & year made.
    My mini has 74k+ miles, 7 yrs old, & runs hot. So I run 0-40 (again, winter is not a variable)
    My Samurai’s engine has 110k+ miles, runs cool, but hot enough to thin 0-40 causing a loss of pressure. So Full Synthetic 50 Straight.
    @Dave.0 What you runnin SoCal?
  20. Justin
    Justin Member
    Jan 10, 2020
    49
    19
    Gets pretty could up here, I live close to Toronto. Some years we see -30°C and my engine runs cold. I have the manic tune and it's set to run cold.
