1st Gen R53 Cooper S Need help!...where does this vacuum line connect?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by clifforddward, Mar 26, 2014.
  1. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    Hopefully someone with an R53 can help...I am finishing up a major service / modification project on my 2004 MCS...in the process I have ended up with a vacuum line that I cannot figure out where to connect. It is the "soft" line that is connected at the right (Passenger) end of the intake manifold...on the inside facing the engine block. Line is about 8-10" long, and has a right angle press on connector on the free end. I left this attached to the intake manifold when I took things apart, so I know that is belongs on the intake manifold....but where does it connect to on the free end?...there does not appear to be a waiting receptacle for it.
    In the photos below you can see the line hanging freely...the line has a natural "set" that seems to show it ending up in this position...but as I say I don't have anything there to connect it to...or have I hooked up something incorrectly?
    https://www.dropbox.com/sc/awvmlg1a71gdhtd/7WmiRQziO0
    https://www.dropbox.com/sc/zg7utts5hvae2l7/abD3iTCUUB
    https://www.dropbox.com/sc/o2gs2m3ij4azawh/LRd9kKJ-Qy
    Any assistance would be greatly appreciated...I pulled nearly everything apart in the engine compartment except the short block and transmission....all has gone back together fine save this one lone vacuum line!
    Best Regards,
    Cliff
    cell: (919) 616-6759
  2. clifforddward
    Dec 2, 2013
    104
    76
    Images of vacuum line
    Here are the images in case some have difficulty with the link:
  3. MCS02
    I know that line but can't remember where the other end goes. I can't look at my MINI because I'm out of town. Sorry but I can give you a bump.
  4. Dave.0
    I found where it goes for you.
    Its under the IC horn right by the fuel rail. I have a picture on my iPhone and I will load it up in a little bit for you.
  5. Dave.0
    Picture 1
  6. Dave.0
    Picture 2
  7. Dave.0
    Its hard to photo but maybe this will help with my Kindergarten MS paint skills. :eek:
      File size:
      17.8 KB
      761
  8. MCS02
    Way to go Dave!
  9. clifforddward
    Dec 2, 2013
    104
    76
    Dave:
    Thanks for the images including your detailed outline of the part. As it turns out that was the same connector that threw me off as I was reconnecting things...that connection comes from one of the several rigid vacuum lines that run on the right hand (passenger) side of the engine compartment....but your photos, sketch and comment about the fuel rail was enough to change my thinking and I realized I might be looking at this offending line upside down...when I considered that, the solution became immediately apparent and the line I am trying to connect runs from the right hand side of the intake manifold (where it is currently connected) over to the center of the fuel rail where it connects to a metal male barb fitting on the bottom of the fuel pressure regulater (#13 in the image below)...it will fit perfectly! (as soon as I can figure out how to route it over there without removing the supercharger again!)...should be possible...I'll just take a break now for dinner and then go fresh into it later on this evening....
    Thanks again for your help...I know I would have looked at this for hours more without your helpful comments guiding me in the right direction.
    Best Regards,
    Cliff
  10. Nathan
    Oh, I've pulled that off before by accident. You'll need to lift up the fuel rail to reconnect it. No need to fully disconnect the fuel rail from the source.
    DON'T pull #10 out. You don't need to and boy is it a real carp to get back in place.
  11. clifforddward
    Dec 2, 2013
    104
    76
    Follow up note;
    I did get the vacuum line properly reconnected. Interestingly enough there was not enough room between the S/C horn and the intake manifold to pass the 1/8" line...I had to loosen the supercharger, alternator, and belt tensioner...then a crow bar wedged between gave just enough room to get the line into position...from there an easy press on.
    Wish I had labeled that line!....I did label most things as I was pulling it apart....but it's always the one you forget that causes the trouble, right?!?
    So I'm back on track....this coming weekend should see much of the front end back together....still plenty of time before MOTD....
    Only about 1/3rd of the front brake pads left, so I'll take the opportunity to swap out for new pads while the rotors are so accessible...that way I can avoid going through the wear sensors and having to replace those as well....
    Still trying to decide if I should install the Milltek exhaust or just let the muffler shop do it...The new header is all installed and bolted up to the old exhaust. I have all new hangers, and have loosened the nuts, so other than the aggravation of crawling under the car and being a dirty job, I have no excuse for not doing it myself...the money I'd save would pay for another goodie for the car....
  12. Dave.0
    Glad you got the vacuum line issue fixed. The Milltek is easy to install since it is two pieces just getting on the floor and under the car is the hard part for me. It's cold and I am getting older.
    Must get a lift in my garage somehow. :idea:
  13. Joker
    Joker New Member
    Feb 14, 2014
    12
    Automotive Euro Tech. TIS
    Phoenix,Arizona
    If im not mistaken it goes to the vacuum canister under the intake manifold because of its connector, i just finnished rebuilding an r55 and only the hoses going to the vaccum canister has that connector. Its the plastic tank right beside the passenger side axle right directly below the knock sensor one line goes to the turbo and the other to the vanos, it does not matter which side you plug them. Ill try to attach a picture.
  14. Joker
    Joker New Member
    Feb 14, 2014
    12
    Phoenix,Arizona
    Wrong picture , sorry
  15. Joker
    Joker New Member
    Feb 14, 2014
    12
    Phoenix,Arizona
    Did you check the solenoids that are mounted under the intake manifold those are the only areas where a vacuum line ca be connected , that size. The solenoid , one is a 3 way and the other is a 2 way, from there it sparates one going to the tank and the othe to the intake manifold
  16. Joker
    Joker New Member
    Feb 14, 2014
    12
    Phoenix,Arizona
    Im trying to find a picture of it installed
  17. Joker
    Joker New Member
    Feb 14, 2014
    12
    Phoenix,Arizona
    Ok here it is , its the black canister directly below the water pump tube
  18. Metalman
    The OP has a 1st gen...
  19. clifforddward
    Dec 2, 2013
    104
    76
    Dave:
    RE: the Milltek.....yep, that's what I figure, it appears pretty easy, nothing to weld, just a couple of pieces, and I have all new hardware....of course history tells me this is when I should run, as these sorts of "easy jobs" always seem to turn out taking forever in the end!...LOL
    Joker:
    Thanks for your comments, although as Metalman mentioned mine is a Gen1 and the vacuum lines are different....I did sort out the issue, so all OK now.
  20. Dave.0
    Word of advice since you have a quality exhaust don't use cheap exhaust gaskets.
    I only use these now and they never break down, leak or cause O2 errors because of the leak. (about $15 bucks)
    They are the right size and they fit perfectly. Made of solid Graphite 50% crushable and makes a perfect seal and good up too 3000 degrees. :Thumbsup:
    Amazon.com: Remflex 6005 Exhaust Collector Gasket for Mopar, (Set of 2): Automotive
