Need to replace H-Sport 22mm RSB
Discussion in 'Tuning and Performance' started by SNEEEZY - Erika, Nov 23, 2018.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    Is the Madness RSB solid or hollow?
    I’m a bit leery of hollow RSB...
  2. Savvy
    You shouldn't be. When was the last time you actually replaced those RSB bushings? Willing to bet they were toast, and had a bunch of grit and road debris in them, causing the coating to get worn away and rust through. You need to keep those bushing fresh and greased. Mine need to be replaced every other year or so.
  3. SNEEEZY - Erika
    1,212
    116
    Female
    I finally found the Hotchkiss website.
    Based on the product description, I have a feeling a warranty claim would be denied because it was installed on my daily driver.
    WMW did the install of the RSB & the camber links at MOTD.
    Bushings were greased with every 5k tire rotation.
    WMW never said a word about “track-only or warranty is void” because my anal-retentive, nuclear & mechanical engineer husband would have vetoed the purchase.
    (The anal-retentive husband is now my ex-husband!)
  4. SNEEEZY - Erika
    1,212
    116
    Female
    Found the warranty info: 36 months.
    To hell with another hollow RSB.
  5. SNEEEZY - Erika
    1,212
    116
    Female
    Does anyone have a discount code for Madness?
  6. Dave.0
    Contact Chad at Detroit Tuned. He will get you exactly what you need. 596-792-6464
    https://www.detroittuned.com/swaybars/
    • Like Like x 2
    • Agree Agree x 1
  7. ScottinBend
    Second for Chad.
    I relube my bushings every year with spring tire change. Easy to do.
    Also, what setting did you run the 22mm at?
  8. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #28 Qik, Nov 26, 2018
    To hell with another hollow RSB.[/QUOTE]
    The 22 was hollow? Thought it was the 25 that is hollow.
  9. wmwny
    4,040
    2,242
    SOLID...when I first got it i thought it might be too heavy because I had never had a 3-hole adjustable rear sway bar before. However, since the Cooper is not raced [but it does the TOTD well], the added weight in the back gives it a bit more stability, I think.
  10. wmwny
    4,040
    2,242
  11. Detroit Tuned
    319
    evertyhing
    Metro Detroit
  12. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,694
    918
    physician
    York, Pa
    ^ I’d go for that one
