New 2% Overdrive Crank Damper
Discussion in 'Sponsor Messages' started by Way Motor Works, Jan 14, 2010.
  1. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    #1 Way Motor Works, Jan 14, 2010
    Way Motor Works is proud to offer the new ATI 2% Overdrive Engine Damper crank pulley for R53 Cooper S. This is an exclusive WMW pulley made by ATI. It uses the same fluid damper technology as their standard Damper, but the size is 2% larger than stock to give you that overdrive to spin the supercharger. We did this because we have several customers using the aluminum damperless 2% crank pullies, but with concerns over engine and bearing life without a damper they live in fear. So this will give them an alternative to get that extra 2% and improved dampening to maintain engine life and reliability.
    Way Motor Works*::*Performance*::*Pulleys*::*Super Damper Crank Pulley R53
