New R53 A2A Intercooler from DoS
Discussion in 'Engine & Drivetrain' started by Mini'mon, Sep 3, 2010.
  1. minimark
    Noticed that the original starting intake temps vary:
    DOS = 120°
    GP = 150°
    OEM = 165°
    What overall effect would that have and I would like to see a RPM overlay?
  2. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    MINI Performance Parts Designer
    San Francisco, CA
    Ugh! This morning is packed for me, but I have some answers.
    The third graph is indeed fair. It was one of the later sessions of the day, the track temps were as warm or warmer than when the GP testing was done, and I was not able to go as balls out as I would have liked due to more traffic as the day progressed. = not a lot of open straightaway in "clean" air. It's the best we could do based on the run group. Be as critical as you like, but we stand by the graph.
    No sir. The IC unit is painted.
    Thanks for the additional selling point. It is appreciated.
    I had a separate hood mounted OEM duct w/foam seal with the different foam layout than the stock for the DoS unit. I used the same duct for the stock & GP, I just tore out and moved the foam for the GP testing.
    I wish that I had detailed pics of all this, but with only 30 minutes between sessions (including a driver meeting after each session), time was at a premium.
    The starting intake temp is good to note, but it's not as important as noting that all of the IC's initially cool as the to similar levels as the sessions begin and then develop prominent variances as the session progresses.
    I have RPM overlays, but:
    1) They make a multi-variable dataset even more heavy.
    2) The line I'm using for the RPM signal still has some "noise", so the RPM curves have a tendency to dominate the graphs due to some point scatter.
    Business is hectic right now, but shoot me an email and I'll try to get the same graphs with RPM curves off to you next week.
    -Clint
  3. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    When possible, it would be great to see some pics of the IC installed and ready to go. IC, any cover, any foam, under hood, etc.
  4. minimark
    Thanks, will do!!
  5. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    #65 Mini'mon, Apr 1, 2011
    Quote:
    Not trying to bust anyone's balls, I just like controlled experiments where the only variable is the item under study. I certainly understand your constraints testing at an HPDE.
    So, what is your expectation of any thermal performance delta with the dispersant ?
    Sure, Happy to help! I believe you have a good product, I like performance parts that actually have value and function.
    I wish that I had detailed pics of all this, but with only 30 minutes between sessions (including a driver meeting after each session), time was at a premium.A picture is worth a bazillion words or something like that......again, I realize your constraints, 'time' this go round.
    -Clint
    Besides being a great protective coating, thermal dispersant (TD) mainly spreads (or "disperses") heat more equally over surfaces. Those that want this option should see lower drops due to:
    1) The coating's ability to help equalize hot spots generated from the charge air output from the supercharger.
    2) The coating's ability to spread out the hot spots generated on the underside of the IC from the intake manifold.
    We have not had time to do logs for TD coated vs. painted, but the use of this coating on stock & GP IC's are excellent case studies in TD effectiveness. Expect to see 2 to 7 degrees in drop from the thermal dispersant dependent upon ambient temps.
    Here's a pic of the IC installed.
    I can get some pics of the foam strip layout on the inner bonnet posted next week. . . wrote myself a note, but PM me if I forget. :arf:
    -Clint
  6. Nathan
    Great to see the progress and data from testing. Thanks for sharing...
    Gotta start saving my pennies faster now!
  7. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    To Clint: Beautiful looking IC. I have a basic question, maybe you or anyone could answer. I have been scouring the internet and can't find other copper ICs, either for Mini or other models. Given the obvious benefits of 60 degrees cooler than OEM, I can't figure out why, regardless of price, copper ICs haven't become the "gold standard" among tuners. After all, tuners stop at nothing to squeeze a little more performance, and a simple bolt-on is a no brainer. From looking at engineering opinions about air density etc, it would appear that 60 degrees cooler would translate into about 7% more power and general efficiencies.
    Any opinions on this?
  8. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    #68 Mini'mon, Apr 6, 2011
    Up until the early 70's, copper and brass radiators were very common. As the need for fuel efficiency reared its head during the gas crisis. Although it is not as durable or as thermally efficient, the auto industry turned to aluminum as their new standard for radiators because it was both lighter and cheaper. Many radiator manufacturers also make intercooler cores, so it's logical that aluminum remained the material of choice for this application.
    That being said, the main obstacles to using copper are cost and availability. Cost is king most of the time. You can get larger, cheaper, aluminum cores made in Asia to create low charge air temps (not as low as copper, but low) at the cost of 2 to 3 psi pressure drop. Tuners can get these larger cores made very easily and make more $$$ per part after markup.
    Due to the dominance of aluminum IC cores, the development of DoS's copper core was very time consuming (read slow). We needed to locate a manufacturer that was willing to work with us at all and willing to make custom, higher tolerance tooling to match our custom plastic endtank mounting details. We also needed this manufacturer to be willing to make our cores in small runs to minimize our up front cost/risk (which still ended up being higher than expected due to the current cost of copper). Doing the cores in small runs allows us to focus on making sure that each unit is built with care at the shop in SF and allows DoS "try out" this new type of A2A-IC with the R53 community to see how it sells.
    Making big margins on some of our higher ticket performance parts (like our A2A-IC) is not and will never be DoS's focus. That's probably because if we marked-up these intercoolers based on common retail "rule of thumb," they'd never sell. :lol:
    Best,
    -Clint
  9. minimark
    What is the weight of the copper IC and how does that compare to the stock and GP?
  10. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    I weighed the IC's before each went on to the car for pressure drop testing. I just happen to have this info in my lab notebook.
    Stock w/plastic Diverter= 4lbs, 4oz
    GP w/plastic Diverter = 5lbs, 3oz
    DoS A2A-IC* = 6lbs, 8oz
    (*There's no diverter on the DoS product. The surfaces for the foam seal in the bonnet are integrated into the design.)
    Yup. Copper is heavier than aluminum . . . but the DoS IC core is also 1/2" thicker than its stock and GP counterparts.
    Best,
    -Clint
  11. minimark
    Thanks! Not a significant weight gain.. :)
  12. Metalman
    Shoot.... Just stay away from the biggie fries for a week and there won't be a weight penality.:D
  13. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    Under Bonnet Foam Layout
    mini_racer, thanks for the reminder. Here you go!
    Best,
    -Clint
  14. mini_racer
    Engr Manager
    Thanks for that and sorry for the delayed response.
    Looks like a simple rip out of the OEM foam, a small trim of some plastic, and then the installation of your foam. Looks neat and tidy enough to me. :Thumbsup:
  15. BlimeyCabrio
    Found any red thermal dispersant yet? :devil:
  16. Dwight
    Dwight Racing with the Gods
    329
    12
    RETIRED!!
    San Marcos, Calif.
    I doubt if they make it. The black color alone aids in dumping heat. If you just paint the IC you'll degrade it's ability to disperse heat.
  17. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Was thinking about this little gem the other day, and thought of something. Are the interior fins of the I/C coated as well ? If not, would you not be worried about tarnish/corrosion setting in ? IF it does, how does a non-polished or non-raw (shiney) surface compare to heat transfer ?
  18. Mini'mon
    Mini'mon New Member
    Jul 16, 2009
    142
    39
    San Francisco, CA
    Hi All,
    The two colors that I've found are black & a dull gray. The thermal dispersant is about function and not at all about flash.
    We can do a red painted IC for you that would be coated in an intercooler/radiator appropriate paint, so there's hope for you yet! :D
    The interior fins are not coated. The copper and brass alloys that we're using are more corrosion resistant than the aluminum alloys used on most IC's and radiators. :Thumbsup: If left uncoated, they will get a light oxidation on the outer surfaces. (Aluminum does this as well.)
    As for the heat transfer question (raw -vs.- painted), we've never tested an unpainted IC. There's not much sense in doing so because we'd never sell an unpainted or uncoated unit to a customer. We apply a protective coating to every IC ensure that each one keeps looking great for years to come.
    Best,
    -Clint
