Interior 1st Gen New really crazy idea
Discussion in 'Tuning and Performance' started by mrntd, Nov 1, 2013.
  1. mrntd
    I had the idea to change the R53 steering column out for the R56 one. I would really like to have the wheel closer.
    Has anyone ever done this or looked into it? Is there a different option?
    Why not put a spacer under the steering wheel to move it closer to you.
  3. BlimeyCabrio
    I happened to chime in way back then in 2008 when this was brought up.
    I wrote...
  5. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Current MSRP $ 675.86
    I think growing longer arms might be easier. :wink:
  7. ScottinBend
    Actually shorter legs would be easier.........they have electric tools to do that.
  8. TheModFather
    Stop thuggin around with your seat laid back...
    A spacer would be the easiest option.
  9. Dave.0
    The seat moves back and fourth or are you a T-Rex? (Long legs, short arms)
  10. Nathan
    Sorry I just had to...
  11. mrntd
    I'm not quite as bad as old T-Rex. It does look like a lot of work. I figured it would be.
    Is there such a thing as a spacer for the stock wheel set up? I know I've had them for my MOMO wheels in the past. I'd like to keep the controls and air bag.
    Thanks for all the input.
    You will probably need to machine this yourself. Just be sure to keep the center hollow to pass the wiring. Also, before you take the steering wheel off and disconnect the airbag disconnect the battery to prevent the airbag light from coming on. Mark the TDC on the column and steering wheel to make sure it goes back on in the same spot.
