Newbie with a Gas Cap Question
Discussion in 'Starting Line - New Member Introductions' started by damockstadad, Sep 25, 2015.
  1. damockstadad
    damockstadad New Member
    Sep 25, 2015
    I own a 2006 Mini Cooper S that recently threw a EVAP code that I was told by the auto supply store the seal was bad on the gas cap. Is this a common problem for my vintage car with 48,000 miles? Also, is a replacement gas cap a dealer part or is it available from auto supply stores? Thanks for your help!
  2. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
  3. eMINIparts
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Most likely not from mileage , but from age yes. The seal can deform overtime and cause a slight leak enough to trigger a check engine light.
    Happens on new cars as well.
    MINI Parts -
  4. MCS02
    Welcome to MA!
  5. wmwny
    4,048
    2,246
    Welcome to M/A! Hummmph...VINTAGE CAR? Ohhhhh...the agony [says the guy with TWO '06 Vintage Cars and a "caveman era" '03 Cooper].
    I have never had an issue with a MINI gas cap leaking...I make sure it "clicks". However, some other cars I have owned [before my MINIs] had problems and the dealers always told me it was because the caps were not fully twisted on. So, I try to make sure the caps are always "on tight".
  6. Nathan
    Jeff you are the vintage part of your car collection. :wink:
  8. wmwny
    4,048
    2,246
    Yep...that would be ME...just your average, non-technical VINTAGE Silverback, and proud of it! :Thumbsup:
