Engine Drivetrain 2nd Gen S NM Eng Catch Tank
Discussion in 'Tuning and Performance' started by GreyLens, Jul 9, 2013.
  1. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    I've been contemplating a dual but was concerned about the available real estate under the bonnet.
    Pictures please?
  2. GreyLens
    GreyLens New Member
    259
    71
    Electrical Engineer
    San Antonio, Texas
    In my reading...not sure where...the point was made regarding the diameter of the hoses/holes into and out of the can. I see several have fairly wide diameters but the NM Eng one seems narrower. Does anyone see that as a problem? Any experience in that regard?
    Btw, thanks for all the discussion. I didn't expect this level of response for an older subject...but this has been very helpful.
  3. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    There are two basic styles of Oil separator.
    The typical "pressure drop" type OCC functions to reduce the velocity of the vapor/oil mist such that the oil droplets "drop out" of the flow. Inside various can designs there are mist eliminators, mesh, or other "filter" media helps to encourage the very fine mist droplets to agglomerate into larger, heavier droplets that will more easily drop out of the flow stream.
    A vortex separator type of OCC uses a fast spinning stream of vapor/mist within the can to sling the heavy oil droplets out of the main flow. The heavier oil collects along the inside wall of the can and drains to the bottom. Vortex separators have a tangential inlet port to facilitate the centrifugal spinning action.. and the exit port is at the center/top of the can.
    A reduced port size for the typical OCC would accelerate the flow...which would seem to be counter-productive to effective oil drop-out.
  4. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    There's a couple pics of my dual OCC install in "My Garage". I'm in process of changing the air intake plumbing, but that won't affect the OCC install. No pics of the drain extension, yet --- I don't like taking my Canon under the car with me. However, here's what Saikou Michi sent me --- the dual gets two of everything.
  5. HurricaneDave
    HurricaneDave New Member
    Apr 9, 2012
    99
    34
    Tellecommunications Engineer
    Ball Ground, GA
    Oldbrokenwind. I'll take that OCC off of your hands if it is still available. Sent you a PM, let me know.
