NM Power Module
Discussion in '3rd Generation Parts For Sale' started by vetsvette, Jan 19, 2018.
  1. vetsvette
    #1 vetsvette, Jan 19, 2018
    This has worked flawlessly for me. The only reason I'm getting rid of it is because I replaced it with a ECU Tune. The NM is especially good if you're still under warranty because it can be removed in 5 minutes before taking your car to the dealer for service. Never caused a problem or a CEL, which is not a claim that the Dinan Sport can make.
    $250 shipped to CONUS SOLD
    NM Engineering Power Module is a device which easily allows most able person to upgrade the performance of their new MINI Cooper F56 without reducing the reliability or integrity of the engine, clutch and driveline. This is the simplest and best alternative or option to chip tuning. The NM Power Module is an all new propriatery tune box designed specifically for the F56, not some rebranded 3rd party product for the BMWs. It is a plug and play box that intercepts the T-MAP sensor and can be installed or removed within minutes without any detection. The electrical components are housed in a billet aluminum enclosure which is protected from the elements and is designed and manufactured to be positioned within the engine bay of your vehicle. The wire harness is manufactured using automotive quality wiring which is both oil and heat resistant, and has the same OE water proof connectors as used on your engine.
    Features:
    Two position switch:
    LOW: 91+ Premium Fuel (+23HP/+23TQ)
    HIGH: 100+ Octane Fuel (+44HP/+34TQ)
    Functions:
    Allows ECU to remain in control of boost
    The actual boost is increased by a precise amount
    Boost is increased in a gradual, progressive fashion
    Correct Air/Fuel mixture maintained from the wide band O2 and closed loop mode of the ECU
    Ignition timing optimized by the ECU
    Retain factory engine safety protocols
    Not effected by ECU reprogramming by the dealer
    Plug-and-play intercept at T-MAP sensor connector location
    Installation or removal can be completed in a few minute
    No trace Power Module was ever there after removal
    Power Module can be sold or transfered to another vehicle of the same engine type.
    Notes:
    Not to be used with 1.5T Engine
    OBDII displays actual boost and not compensated, which makes the module compatible with all OBD reader/scanner, such as: Scan Gauge, P3, PLX, Torque Pro, etc.
  2. tsmetjen
    tsmetjen Member
    Jan 16, 2018
    45
    54
    Is this for f56 Mini Cooper S?
    Verzonden vanaf mijn iPad met Tapatalk Pro
  3. vetsvette
    Will work on F54/55/56/57/60. Both S and JCW.
  4. Dave.0
    Bump for a nice guy.
  5. MCS02
    Bump Good luck with the sale!!
  6. vetsvette
    Appreciate the bumps guys, but there's not much chance of a buyer on M/A. Just figured I'd give it a shot since the last for sale item in the 3rd Gen section was 47 weeks ago. If all else fails I'll bring it to the Dragon and sell it there.
  7. tsmetjen
    tsmetjen Member
    Jan 16, 2018
    45
    54
    I’m hesitating, but live in Belgium, so it probably is too expensive to send it to here and I have an EU f57 MCS, no warranty at all From the company I believe
  8. vetsvette
    I just got a quote of $35 USD for shipping to Northern Ireland. If you're interested I would need your mailing address to get a quote for you. I'll even split the cost of shipping if you decide to buy it.
  9. tsmetjen
    tsmetjen Member
    Jan 16, 2018
    45
    54
    9320 Erembodegem Belgium
  10. vetsvette
    Looks like $35.25 shipping.
  11. tsmetjen
    tsmetjen Member
    Jan 16, 2018
    45
    54
    I will dig into deeper for now because a lot of players of chiptuning on European market
  12. vetsvette
    SOLD
  13. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Glad its sold!
  14. vetsvette
    Strange. The only offer from the US was from some troll that made me a ridiculous lowball offer. But, I had interest from people in Northern Ireland, Belgium, and UK even though shipping was $35. Ended up going to UK and I split the shipping with him just to get it gone.
    Thanks for reading. I will have some 2nd Gen stuff to get rid off in the near future as I get my storage building cleaned out.
  15. tsmetjen
    tsmetjen Member
    Jan 16, 2018
    45
    54
    Congratz!
  16. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    I pick up the GP2 tomorrow.. lmk if any of the parts you have would work on it... there are some bits I’ll look to replace once I do some research. For example, I don’t like the intake.. pulls in hot air. Would like to isolate it.
  17. MCS02
  18. vetsvette
    Sorry guys. The AEM went with the R56 when I traded it in. And, don't you have the N18 motor? Mine was for the N14. Not interchangeable anyway.
  19. MCS02
    Sully has the N18 I have the N14. I knew I would not be that lucky
