1st Gen R53 Cooper S No oil 'idiot' light...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Goldsmithy, Jun 19, 2015.
  1. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I have 2005 R52 S that I got 4/29. The car runs wonderfully: however, the oil pressure warning light doesn't work. As I understand it, the light should come on at key position 2 or when the engine is cranking. Before I start tearing things apart (and maybe miss a day of sunshine :) ) I would appreciate any imput.
    There are no codes. Should there be? I have an electrical oil pressure gauge ready to be installed, but haven't finished the install yet.
  2. BlimeyCabrio
    Is there a fuse for that? I think there may be...
  3. ZippyNH
    Have you pulled the switch....
    Being a simple pressure switch, it might just be stuck in one position aka, failed internally.
  4. Metalman
    Quicker to check it with a ohm meter... If it's closed an ohm meter will let you know...
  5. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    often times pulling the plug to find out if the plug is full of oil is a good way to check also.
  6. rkw
    rkw Well-Known Member
    443
    First, as a sanity check, can you other guys verify this (I no longer have a MINI to check myself)? I know some lights come on but I don't remember if the oil light was one of them.
  7. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    From my R53 manual:
  8. ColinGreene
    438
    293
    Orange county Ca
    What i mean by my post is the plug for the pressure sender.
    Sorry if that was not clear.
