How To No start
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Michele, Apr 24, 2019.
  1. Michele
    Michele New Member
    Aug 26, 2018
    Female
    #1 Michele, Apr 24, 2019
    Got a 341 code used timing tool changed sensor twice ...now I'm fixing to put new battery.... (problem is turn over no start )..
    Help please
    Could you give a little more info. Year, For non S, milage, any mods?
  3. Michele
    Michele New Member
    Aug 26, 2018
    Female
    Sorry just saw post...
    No mods,manual 6 speed supercharged,
    2002
  4. wmwny
    4,040
    2,242
    mileage?
  5. Michele
    Michele New Member
    Aug 26, 2018
    Female
    320,000 roughly I'm not close to car at moment I've only had the car 2 years and out of the 2 years I've driven it one 1 year because last summer the sensor went out
  6. Dave.0
    Well, if you don’t know much about cars I would take it to a dealership or a local MINI shop .
  7. Michele
    Michele New Member
    Aug 26, 2018
    Female
    I've personally been fixing this car myself can replace the camshaft sensor in just 30 minutes ,just has me baffled that the same code keeps coming up,,,I've changed the crankshaft sensor, oil pan gasket ,and the top gasket new coil,new plugs,new plug wires,new battery....thanks for the advice...i'll try a new forum
  8. Dave.0
    Well, your posts lacked a lot of details. Try checking your main ground on the front passenger side. Also check the positive power post under the hood by the air intake. Both of those will cause your car to not start.
  9. MCS02
    Is it turning over just not starting or not turning over at all? 320k lots of miles you must have taken good care of the car. Make sure nothing is locked up like a pulley, AC compressor, alternator, od supercharger. One guy her a few months ago had a alternator locked up causing a no stair problem.
    Is the timing cain and guides in good shape?
  10. Michele
    Michele New Member
    Aug 26, 2018
    Female
    Just turns over ,,tried to start a couple of times,,,everything else seems fine,,,I did buy the timing tool and timed it to be sure of the timing
  11. wmwny
    4,040
    2,242
    We try to help in this forum, given the info we need to offer the help you want.
    Welcome to M/A, and good luck! :Thumbsup:
  12. Dave.0
    Fuel pump fuse or OEM fuel pump failure
  13. 00Mini
    If'n you had any wiring connections apart recently maybe that could be a place to check.
  14. MCS02
    @Michele Ok if it is timed correctly and the chain and all is in good shape. I would pull a plug and make sure your getting spark. then I would check the fuel pressure, like Dave said it could be a bad pump or blown fuse. It could also be a clogged fuel filter. I changed mine on my 02 at around 160k and it was a mess. If you don't have a fuel pressure gage you can get cheep one at Harbor fright or we sale tools.
    Let us know what you find
  15. MCS02
    Also check the plug on the sensor you changed. Make sure it is clean, in good shape and plugged in good. It could be the plastic peace that keeps the plug secure is broken or not engaging well, allowing the ends to slip apart. Check the length of the wire from the sensor as far as you can and make sure there is no brakes or chafing. I had an E30 BMW that the wire from the crank position sensor had chafed. some times the car ran fine some times it would not crank. It took forever to find it. Long funny story, I won't bore you with it.
  16. Michele
    Michele New Member
    Aug 26, 2018
    Female
    Thanks for all the advice orderd another camshaft sensor (my 3rd) if this doesn't work ,then junk yard bound
  17. Michele
    Michele New Member
    Aug 26, 2018
    Female
    Also fuel rail has great pressure, don't think it's a fuel peoblem....you guy's are great!
  18. MCS02
