Engine Drivetrain 1st Gen Cooper S Ns1 cam sound
Discussion in 'Tuning and Performance' started by Tummi_Gummi, May 18, 2014.
  1. Dave.0
    Jimmini did you steal your laptop back from your wife again?
    You going to get in trouble again. We have not missed you.
    Did you every get your 80's tribal striped ride back and running again?
  2. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Awww.......it sounds like you have missed me Dave......but I'm taken :wink2
  3. Dave.0
    #43 Dave.0, Jul 20, 2014
    I thought she left you too.
    Here's the funny part of all your posts, you talk all this BS on the web but when I say I am coming out to Cali you clam up and go underground for a month or so. :confused5:
    What's the problem? Did you not want to see me face to face and talk crap? :cryin: I did not think so..... web muscles. :frown2:
  4. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    Wait what's wrong with the Msd ignition?!
  5. Dave.0
    #45 Dave.0, Jul 21, 2014
    Do a little research and reading up on the MSD coil in an MINI and you will see what they have been known to do. It's not good and cost $$ to repair.
    Stay with the OEM coil.
    UPDATE: I did the Google research for you.
    The MSD has been know to cause expensive problems like fried ecu. No gains & a chance for a big loss.
    Yes its a "known" "possibility" with minis in particular that they cook, and it has been "known" to cook computers (DME) or other electronics.
    Over the years, we've seen cracked MSD units and more problems than solutions. If you're willing to spend the money, it's your choice.
    Just keep in mind that many higher HPs Minis are still running the oem coil pack, mainly because that except for corrosion on a terminal, those things are pretty reliable. Nothing that a once in a while inspection and some dielectric grease can't prevent.
  6. MCS02
    6,303
    I have always believed high out put ignitions do nothing until you are looking for that last little bit of performance left to squeeze out of a motor. Even then with modern systems that is suspect.
    Well that was fun, just catching up to this thread.
    Now play nice boys...
  8. MCS02
    6,303
    Oh……ok we will.:D
  9. Dave.0
    "Crickets" went back under his rock or his wife took away his laptop again.
    Its all good.
  10. Jan
    Jan Well-Known Member
    377
    382
    as I said from the start and was proven correct.............the stock ignition coil is good to at least 600whp...........so why would you need aftermarket parts that HAVE BEEN PROVEN TO FRY ECU's???? We have already replaced at least 4 ecu's with fried ignitors inside the ecu. That's a bare minimum repair bill of $1800.........
    So tell me again WHY WOULD YOU DO THIS?
  11. yellowbritishrocket
    May 16, 2009
    618
    277
    oooooh SNAP!
  12. cct1
    For the same reason people buy intercoolers that raise IATs more than stock, restrictive cold air intakes, certain types of superchargers, and cams that take a stock MC S to base Cooper levels..,:mad2:
    That, or they look nice, can't figure out which.
  13. ZippyNH
    One word....
    Butt-dyno/pleceabo.....and NO, NOT THE STRAPON KIND!!:devil: interestingly enough the effect is the same....you got f$%ked!!
    Owner spends money....feels better!! Granted...sometimes a new INFERIOR PART IS better than a worn or broken OEM, so there might be a change before vs after....just not as good as new OEM or quality part....
  14. TheModFather
    Looks like I missed out on the fun...
    Listen to the people who are trying to save your car, not the ones trying to sling parts. Just because something is shiny red and new, doesnt mean there is an advantage to it... The MSD, wasn't even made to be used on a MINI, why do you think you need to drill the mounting holes out to get the screws in? (Maybe they fixed that issue)
    NS cams have been linked to a ton of problems... Misfires, sub par running conditions, loss of power over a stock cam, the list goes on... Seems like before I was banned from the Mynes forum, there where a lot of those guys swapping their NS cams for CAT cams... Kinda makes you wonder why doesn't it?
    If Mr Cricket gets his posting time back from his wife, maybe he will come back into the thread and explain that one for us...
  15. jiminni
    262
    Ca.
  16. TheModFather
    Aww... Isn't that cute.
    Didn't expect any less from you.
  17. Dave.0
    Looks like someone's "friends" are not available to tell him what to say anymore all he can do is post pictures.
    Here is a picture for you.
  18. TheModFather
  19. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    That's a bad father. You should never teach your kids to point. It's a dead give away.
