1st Gen R53 Cooper S O2 simulator
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by narvarr, Apr 15, 2015.
  1. chuckt
    chuckt New Member
    Oct 16, 2009
    19
    Yes, it's a Magnaflow. 2-1/2" I/O w/2 bungs... P/N 94166.
    Jury's still out until I can get it to run code free.
  2. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    I run a 90 on mine and keep getting the P2096 code. I didnt think there was enough space in the tunnel to put a straight one in?
  3. Dave.0
    Use a Random Technologies CAT or find a used 911 CAT.
    Been using Random Technologies CAT's. Keep blowing them out.
    Header is RMW Race.
  5. narvarr
    narvarr Active Member
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Rowlett, Tx (Dallas Metro)
    The Magnaflow 91036 CAT goes for about $80 on ebay. Dave or Nate, either one of you guys have a part number for the Random Technology CAT your using?
  6. Nathan
    141-25000- 2-1/2" inlet/outlet Round, Metal Matrix (Race style) 7000 Series
  7. _iD
    _iD New Member
    Apr 5, 2014
    62
    23
    Dave, did you have to get a new bung added to your shorty to fit the extender? The post cat bung on my rmw shorty is positioned such that there's not room in the tunnel to add the extension.
  8. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    The only high-flow cats that I have seen consistently work are HJS cats. The only problem is their price: they're very expensive. I've had spotty luck with the defoulers (extensions), whether they be right-angled or straight.
    If you want to do it right, spring for the HJS cat. It'll hurt the wallet, but reduce headaches in the long run.
  9. Dave.0
    Nope no new bung, its tilted down so I have room and no issues.
  10. narvarr
    Nov 8, 2014
    183
    116
    Maintenance Tech
    #30 narvarr, Apr 21, 2015
    Where is the best spot to add a second bung for a wide band? Since I'd have to get the donut fitting welded on to the cat, I was thinking of having it add before the cat. Would that work or is it too close?
  11. narvarr
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Eric, on the HJS cat, what c.p.s.i do you recommend?
