OEM LSD for R53 - SOLD
Discussion in '1st Generation Parts For Sale' started by jasonsmf, Jul 4, 2013.
  1. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    OEM LSD for R53
    OEM Limited slip differential out of a 2006 Cooper S 6 speed R53 with 18,000 miles. This came with a replacement transmission I purchased but was not needed as I was using an aftermarket LSD.
    Will ship to the lower 48 states USA.
    List Date: 7/4/2013
    For more info, click here to view the original listing: OEM LSD for R53
    Item Has Been Sold.
    Sweet deal, If I didn't already have one it would be mine.
  3. ScottinBend
    Hmmmm......do I bet on the clutch going out soon?
  4. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    May be a stupid question but will this fit the early Getrag 02-04?
  5. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    I'm pretty sure this will fit all years of R53s. I have even heard of these being used successfully in R56 Cooper S's.
    I'm sure your clutch is about to go Scott. Might as well get the slip & throw them both in at the same time. :yesnod:
  7. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Crashton is a wise man, not frequently known to be wrong :) hehehe
  8. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    Jason's a stand-up guy. I'm sure if you tempted him with a case of IPA (and perhaps a Brinks truck full of money) he' d even install it for you... ;-)
  9. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    :Thumbsup:
  10. ScottinBend
    Kind of a long drive on an apparently worn out clutch ......... :biggrin5:
    Good luck with the sale, I will be watching to see whan it sells.
    I can assume this is a Torsen/Quaife style LSD and not a plate type?
  11. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    The OEM LSD is a clutch type. Cone clutch actually from what I'm told.
  12. ScottinBend
    Ahhhh......I didn't know that.
