Oil Catch Can Hoses
Discussion in 'MINI' started by TGS91, Nov 19, 2009.
  1. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Hey, we were talking about Oil Catch Can's a couple weeks ago. I've been rooting around EBay and there seems to be many choices at about 1/4 to a 1/3 of the cost of some of the MINI after market companies.
    I noticed that most on EBay have a PVC/Silicon type hose that looks kinda thin. On some of the applications I've seen on MINI's there is what appears to be a pressure hose of some sort. Where would I get some of this. Any autoparts store? Suggestions?
  2. Metalman
    I use McMaster Carr a lot for hard to find parts. They also have fittings. Here is a link to the hose selections.
    McMaster-Carr
  3. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    looks spot on
    thanks Metalman!
  4. ScottinBend
    I just went to the auto parts store and got some heater core hose that fit the barbs.
  5. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    This was what I did after the hoses that came with the kit started looking burnt and hard.
  6. Boxcars
    Boxcars New Member
    May 27, 2009
    80
    tim
    i went to pep boys and bought goodyear gas and oil rated 3/8 inch hose a few bucks a foot,
    works great!
    boxcars
  7. Metalman
    It's always better to pick the correct hose for the application. A hose for an oil catch can should have good temperature resistance and be able to handle petroleum products versus say a water and antifreeze solution.
  8. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Metalman,
    The link you sent me had several choices. Question is what psi rated hose would be best for application?
  9. Metalman
    My feeling is the psi (pressure) is not very important. If you look at the way MINI attaches the stock hose to the fitting on the valve cover (R56), it's just a push on with a decorative plastic clip. The OEM hose is not even reinforced. The nice thing about McMaster-Carr is the additional information they supply with their product. I don't know what diameter hose you need, but notice they give you the bend radius (indication of how tight a bend you can make). Look at the temperature range and stick with a grade designed for petroleum-based oils. The other nice thing about this company; they can custom make the hoses to your length and add special hose fittings for a cleaner installation vs say the standard method of using hose screw clamps.
  10. ScottinBend
    There shouldn't be enough vacuum to be of a concern. I don't even have hose clamps on mine.
