Engine Drivetrain 2nd Gen S Oil Catch Cans let me know what you think?
Discussion in 'Tuning and Performance' started by gjn25, May 15, 2011.
  1. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    What separates this can from the others available ?
    And IMO the brass fittings do not "add a modern look", in reality it adds a bit of "my home project" look to it.
  2. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    There is a two chamber design inside the Catch can that helps Catch the Oil vapors.
    As for the brass fittings, the problem is there are not many fittings that can with stand the amount of engine heat that comes from the engine bay or the the break down of the material due to the oil being consistently being in contact with it.
    There are some nickel plated and chrome plated brass fittings out there but they tend to get pricey real quick...
  3. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    Our valve covers are plastic. Filter boxes, ect. I doubt heat will be an issue for any part in that area.
  4. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    The Can is unscrewed from the bottom.
    This is also something that is concerning us .We are looking to fab up a billet bracket.
    Thanks for that. We really do take pride in how our
    product looks as well as how well it works
    We have also been looking into that,The techs and mechanics we have spoke to do not agree with blocking it off. Thats why we are looking into
    a dual catch Can set up.
  5. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    Different type of materials bud. We have already tried different fittings "Plastic/composite on the other platforms we make these for and they have failed miserably :(
  6. BThayer23
    Have you guys tested this catch can on an R53?
  7. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Commercial Photographer
    Palm Beach, FL
    thank you 1FST4DR for stepping in I will be seeing you soon :D
  8. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Happen to have a cut away to see how this top and bottom baffling works? And maybe a vid of how you empty it from the bottom? Thx.
  9. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    here is a vid i made a lill after install that i just uploaded to youtube. please for give the vid i know i suck at this but the OCC works :biggrin5:
    [ame=http://www.youtube.com/watch?v=eSxV9D98CCU]YouTube - Billet Technologies Mini Cooper S R56 passenger side set up prototype[/ame]
  10. BThayer23
    Looks like you just grab the knurled section on the bottom and unscrew it.
  11. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    sorry vid is so long i just cant edit it could have been only about 1 min long SORRY....
  12. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    thats it! is ease as can be
  13. jiminni
    262
    Ca.
    Good vid, thx :Thumbsup:
  14. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
  15. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    thanks to all for the good feed back since the vid :postcount
  16. david in germany
    Dec 15, 2010
    250
    I did some temperature testing in mine after a 1 hour drive on the autobahn.
    Temp at the fire wall 98deg,
    temp on my BSH catch can 96deg, valve cover 98deg, temp at the turbo Holy$hit! LOL The fire wall area one needs to be good to a little over 100deg so any metal fittings like aluminum would work without a problem. :Thumbsup:
  17. Metalman
    In my "former" life, I worked for a large plastics company. One of the materials we delt with was a modified PPO material made by GE called Noryl EN265. One of it's uses was for manifolds. It has a continuous service temperature of 250F.
  18. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    Not going to lie I m a bit jealous!!!:drool lol
  19. DneprDave
    From what I've seen, when there are two oil catch cans, they aren't mounted at the same place. So, the alarm mounting tab only has to support one catch can.
    Dave
  20. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    The engine temps in the other applications were in the 250-300* range. And the fittings that were affordable were good to the 250* range.
    Being these cans are aluminum "Great heat conductor" and dissipates rather quickly as well. The cans them selves will see higher then 98*. The consistent cooling and heating of the fittings may have contributed
    to those fitting failures as well. Who knows. :confused5:
    After a few months the fittings we were using began to fail. You can only imagine the exchange rate we had to go through. Im sorry folks im not going through that again.
    Our cans come with Brass fittings. They are 3/8" and 1/2" hose. So folks are more then welcome swap them out at their convenience.
    However I may be willing to offer black composite/plastic fittings rated to 250* but those would be at the buyers risk.
    I hope you understand as I've already been whooped once and don't want to get whooped again :)
    Thanks again for your interest..
    I will have some pics up later today of the actual design.
    Thanks guys/gals.
