Engine Drivetrain 2nd Gen S Oil Catch Cans let me know what you think?
Discussion in 'Tuning and Performance' started by gjn25, May 15, 2011.
  1. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    Agreed, If you can find aluminum fittings in a 3/8" pipe thread and 1/2" hose please let me know..:Thumbsup:
  2. Metalman
    Something to think about....
    Machine your own billet aluminum hose fittings.
    You can drop buying the brass fittings....
    You can eliminate the tapping of the pipe threads....
    You still need to drill the two holes (but you would anyway for the pipe threads). Press fit the billet hose fittings into the can and tig weld from the inside of the canister (assuming there's room).
    Clean all billet look...
    Anyway just my $0.02 worth...:D
  3. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    Actually being a CNC machine shop we dont weld, so that leaves the welding out. If I have to out source then the price goes up.
    All great ideas. However I utilize the same can for 10 different platforms. If I have to customize a Can for a different platform "Mini"then the price goes up.
    I'm able to keep my pricing down compared to others because of the other platforms we already make them for. Hope that makes sense.
    As for machining the fittings. It would actually cost me more to machine them, then to buy them. Crazy right? But its true..
    Thanks for the feed back Much appreciated..
  4. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    BTW Metal Man I love the gauge pod!
  5. 1FST4DR
    1FST4DR New Member
    May 17, 2011
    9
    Here is some stuff we have done in the past..
    [ame="http://s84.photobucket.com/albums/k19/newtie31/"]Pictures by newtie31 - Photobucket[/ame]
  6. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Commercial Photographer
    Palm Beach, FL
    Dual can prototype is in my car there is the link to the new thread
  7. KittyMini
    KittyMini Club Coordinator
    1,183
    So David, is that 2 different parts you ended up buying? The catch can AND the block off?
  8. TheMadDane
    TheMadDane New Member
    Mar 26, 2011
    Napa
    I've seen everything covered here but one REALLY important one....
    What about the folks who have their factory alarm system mounted right where you are mounting the catch can?!?! :confused:
    Just my 2 cents.
  9. gjn25
    gjn25 New Member
    Jan 25, 2011
    36
    Palm Beach, FL
    New mounting set up take a look its on the new thread
  10. Jason Montague
    #50 Jason Montague, Jul 10, 2011
    4 Hose vs 2 Hose OCCs
    :cornut:What ever happened to the oil catch catch can with 2 ingress and 2 egress tubes? I went to 'Billettechnology.com' and there is no 4 hose oil catch can as was alluded to in the above posts. Does any one know what happened to that idea/technology? Is it unnecessary or what, any one know? Just thought that I'd ask as several of us have bought the 2 hose BSH OCC from Defenders Of Speed recently. Hopefully DOS will come up and 'splain all this on us.':Thumbsup:
    Jason (see: 'new thread' on above post)
  11. Jason Montague
    :cornut: After a lot of research(BSH,42 Stealth OCC,WayMotorWorks,Billet Technology, sewing site, many others), it appears that BSH has solved the 4 hose problem with their 'Dual Boost Port/Tap'. Installing it with the BSH OCC makes both crank case and valve cover gases/oil/dinosaur snot go through the OCC, et viola, cleanest intake air possible. So I also ordered the Dual Boost Port/Tap. This is my(not a trained gear head) opinion after much reading:Thumbsup:
  12. Robin Casady
    Robin Casady New Member
    134
    Any photos or installation instructions PDF available? I'd like to see what it looks like with the dual tap.
  13. Jason Montague
    Remove Old Port, Install BSH Dual Boost Tap
    :cornut: PLEASE PLEASE tell me how to get the OEM port off such that I can install my BSH Dual Boost Tap. I can install the new BSH Dual Boost Tap(I think) if I can just GET THE #$&%*%$ OEM PORT OFF! Once some one has told/shown me how to do this, BOY will I have a good 'friggin' story for the "FRIGGIN THREAD" of our very own agranger.
  14. Metalman
    It attaches to the rigid PCV hose at the left rear part of the valve cover (just makin sure you know where you are pointing). Look closely and you will find a plastic ring. You will need to squeeze the ring in order to disengage the locking tabs (use you finger and thumb and not a pair of pliers or you could snap the plastic). It works much like those tops you squeeze to open a container of aspirin. You may need to work at it because it can be stubborn.....:D
  15. Jason Montague
    :cornut: Thank You very much!:Thumbsup:
  16. Jason Montague
    :drool DONE!!!!!!!!!!!!!!!!!!!!:lol: MM :cornut: you're a Gentleman and a Scholar Sir and there are damned few of us left although there seem to be quite a few on the MA site.:Thumbsup:
  17. Metalman
  18. Jason Montague
    :cornut: Thanks for the update MM. NM's Can and Block off valve strengthens the argument for one can with block off vs 2 cans. Margi's(08 R56 MCS/JCWm) BSH valve/can system gets emptied(syringe through the top or via valve/hose through the bottom) every 200mi or so of 1-2oz of 'dinosaur snot'. Myself, I would not try to recommend NM over BSH or vice versa, take your pick. The NM product wasn't available when I purchased the BSH valve/can from Defenders Of Speed.:Thumbsup:(for an incorrigable MINI OCD like me, it's one more thing that we can do to feed our addiction):lol::lol:
  19. mysticturner
    mysticturner New Member
    I called Billet Technologies on Friday to check on the availability of the MINI OCC. They had such poor response they never produced any after the first batch or two. However, they are about to setup to run more OCC's and if you call and get on the list, they will produce MINI OCCs to fulfill any requests. You have about 2 weeks. The site address is billettechnology (dot) com.
  20. GreyLens
    GreyLens New Member
    259
    71
    Electrical Engineer
    San Antonio, Texas
    I'm a big fan of many of the NM products and this looks to be another good one. Will get one installed in the next few weeks.
    :cornut::cornut::cornut:
