Exterior 2nd Gen Most liked posts in thread: Oil change = window not working
  1. TinyEdge
    TinyEdge New Member
    Mar 16, 2013
    r56....
    However, I did some searching (should have done before I posted but as a newbie MINI owner I was just in panic mode) I found how to reset both issues!!!! Thanks for the help.
    BTW if anyone else needs to know.....to fix the "sealing" when the door closes you roll the window up and hold for 10 seconds. To fix the one touch roll up you roll the window all the way down and hold for 10 seconds then roll all the way up and hold for 10 seconds and Voila!!!!!
  2. Jason Montague
    :cornut: I'm glad that you found it but never worry about asking questions around here. It does seem better when you find it yourself though, doesn't it? The R56 computer programer for the windows was on dope the day that he programed the windows on 07-09 R56's. They all have these window peculuarities. :Thumbsup:
    It's great you found the answer and shared it with us all. Thanks. I had no idea there was this self healing function for the windows.
    Moved this thread to 2nd Gen Exterior since it is about the windows.
  4. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Whelp...You learn something new every day. Thx!
  5. Jason Montague
    :cornut: Which MINI do you have? R50, 52,53,55,56..............................:Thumbsup:
