Engine Drivetrain 1st Gen Cooper S Most liked posts in thread: Oil cooler adaptor plate
  1. Dave.0
  2. LosOsosS
    LosOsosS New Member
    Nov 14, 2010
    21
    Los Osos, CA...near San Luis Obispo
    The adapter plate can also be sourced from Moss Motors, i.e. mossmini.com. It is part of their oil cooler kit, but can be purchased individually. The part number is not listed, but a Moss tech will take care of you.
  3. BlimeyCabrio
    R53 (and R52 S) manual transmission cars have a water cooling circuit through the oil filter housing. Automatic transmission cars don't have this; instead, they have a water cooling circuit for the transmission. Oil cooler adapter plates are designed to work with the oil filter housing on the manual transmission cars (which is different).
    It IS possible to replace the automatic oil filter housing with a manual one, with the integral cooler, then use this to install an oil cooler adapter plate and a cooler. It's not trivial, but it's possible.
    However, no one really needs this. Because the automatic transmission cars are limited to a MUCH lower rev limit, and it can't be increased... the transmission automatically upshifts at about 6250, if memory serves. As a result, automatics don't generate high oil temps like the manual cars. I've driven an automatic first gen car as hard as ANYONE. I dare say, as hard as it CAN BE. And never had an issue with oil temps.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I beleive that Mini Mania sells just the plate for about $100.
  5. minimark
    Sneed's Speedshop has a oil cooler kit and I'm pretty sure Chris will sell just the adapter plate...
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    George at Mini Madness will sells his alone as well.
    You can easily make one with some aluminum and copper or AN fittings and a jig saw. All for under 50 bucks.
  7. minimark
    Yep and George's is anodised red...got to be worth a couple more HP!!!
  8. minimark
    RMW also has just the adapter plate available and is a very nice piece!
  9. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    RED colored parts always adds HP! :cornut:
    Yes MM's O/F adapter is anodized RED.
    This is mine.
    archived picture:
  10. 1r53
    1r53 New Member
    Dec 21, 2010
    52
    Thanks for the info guys, I didn't think that they would sell just the adapter Iguess I Should have called around before posting a newbs ? I do like the one with the two ports for oil temp and pressure
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    No such thing as an old question. It is turn around time with all the new MINI owners to post questions. Most of us old time MINI owners will be more than happy to answer them again!
    archived picture:
  12. ScottinBend
    I believe Sneed also has just the plate available.
  13. 1r53
    1r53 New Member
    Dec 21, 2010
    52
    #11 1r53, Jan 11, 2011
    Whats the deal with that oil filter housing, is that what you are using?
  14. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Slightly off thread topic, but
    your thread and because you asked!
    I run my own designed oil cooler system and OBERG oil filter. The two adapters are to bypass the factory oil filter and cooler. The system goes back through high pressure lines into a oil thermostat,controlled oil cooler/fan assemble back through an OBERG oil filter to the engine. The oil cooler fan is controlled by, temperature,boost, RPM and manual override. There are 3 temperature sensors and 2 oil pressure switches via a bus switch for component activation and monitoring via gauges or data logging devise. Needless to say I have a steady and constant oil temperature in most operating environments. The system has a oil pressure drop of -3/5 lbs at operating temperature and a consistent 180-185*degree temperature coming out of the sump and -175* cooled returned to engine.
    Achieved pictures:
    Achieved pictures:
    Installation picture post re-located Oberg oil filter.
  15. 1r53
    1r53 New Member
    Dec 21, 2010
    52
    Nice setup. I like it :Thumbsup:
  16. Mike
    Mike New Member
    Very nice. What size lines are you running for that system?
  17. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    hmm - mossmini no more.
    I've been looking for an adapter plate that has the proper connectors for oil temp and oil pressure gauges but cannot locate that any longer. I think that's what Moss used to sell.
    Perhaps I should just get the proper in-line AN T-connectors and go with an ebay cooler kit. They look ok, with all the proper parts, except none of these oil cooler kits (not even the $$$ kits at Way and other Mini vendors) come with a thermostat valve. I really don't want my oil cooler to do anything until it needs to cool, so no matter what I do, I will probably have to hack this whole setup myself from parts bought from various sources.
    Low on my to-do list, but oil coolers are shiny :)
  18. melvinyip
    melvinyip New Member
    Apr 26, 2015
    19
    May I ask if there is a difference for this oil cooler adaptor plate between manual and auto transmission r53 cooper s?
    Most aftermarket oil cooler I see for sale are stated with a disclaimer "this oil cooler will not fit minis with automatic transmission"
    I'm looking to mod my stock oil cooler as well, sadly mine is an automatic. Not sure if there is any oil cooler which is suitable for my application.
  19. vetsvette
    And, it even works upside down!!! I've been looking at this mod for my R56. Expensive, but with my high mileage motor it sure can't hurt.
  20. ScottinBend
    With all of the track days I have done I have never had a temp in the oil pan go above 120° C. Well within spec's for todays synthetic oils.
