Engine Drivetrain 1st Gen Cooper S Oil Cooler Options
Discussion in 'Tuning and Performance' started by mini_racer, May 12, 2009.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    #41 mini_racer, May 31, 2009
    Ok, it seems about average as there is no thermostat and the heat exchanger is tube in fin. The write-up claims MINIs coming off the track with 300+ degree oil temps, but does not indicate how much better it was measured with this kit.
    Also, is there an accommodation for an oil temp and press sensor/sending unit?
  2. ScottinBend
    Yea......it seems at this point the Madness (unfortunately) unit is the best option with an added thermostat.
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #43 Nitrominis, Jun 1, 2009
  5. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    I just installed the Tapless adapter for my oil pressure gauge from CravenSpeed. Nifty little part there :Thumbsup:
  6. mini_racer
    Engr Manager
    Ok, great suggestion on the Cravenspeed tapless adapter!
    So is the existing sending unit for pressure and for OBD input... I am guessing?
    So, what if you wanted an oil pressure gauge as well as an oil temp gauge???
    1. Do you have to daisy chain these things together? Having 2 of these things stacked does not seem like a neat and tidy, or reliable install.
    2. Is it unneccessary to want both, just get a pressure gauge?
    It seems like this location would be best for oil pressure, and temp would be in the pan, or some other more cetrally located spot.
    I realize that oil pressure is directly related to the oil temp, but if you are adding an oil cooler, wouldn't you want to measure the temp directly as well?
  7. mini_racer
    Engr Manager
    So, what kind of gauge did you get and mounted where? Show us a quick pick please.
    Slightly off-topic, definitely but related.
    Craven made me a double tap so I could have both. To bad I'm not using them right now. One day...
  9. mini_racer
    Engr Manager
    #49 mini_racer, Jun 1, 2009
    Ok, a double tap CravenSpeed would work, but still not the best location for temp as it is not exactly getting a nice flow right there. You will get a measurement for sure, and definitely way better than nothing, which is what I have today. :(
    However, it will be more of an RMS value, meaning you will miss any spikes in temp up or down. For example a cold rush of air flow over an oil cooler would not be measured for minutes later on the gauge and only as a slight dip.
    Still, a double tap might be my first location for an install, thanks for the solution.
  10. ScottinBend
    This is great for the pressure gauge, but the OEM temp gauge is my suggestion. It replaces the drain pan plug with an electric sending unit.
    Anyone have a suggestion for a t-stat for this or the Madness cooler?
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #51 Nitrominis, Jun 1, 2009
  12. ScottinBend
    Post #8 has no info on a T-stat.......just that you used one. :nonod:
    Found no price on the Earls one..........do you have a guess on price?
  13. Nathan
    About $110 at Summit
    BTW it has 3 sender ports in it as well, negates the need for a tap.
  14. mini_racer
    Engr Manager
    Thanks Nathan, well not cheap but an important component of the system for street cars, or cars that pull double duty street/track.
    So, does anyone have this t-stat, and if so, where did you mount it? I am thinking closer to the engine as opposed to closer to the cooler, especially if you will be utilizing for temp and pressure sending units. I think I will skip the flow sending unit.
  15. ScottinBend
    So the best bang for the buck system seems to be the Moss MINI Cobalt set-up with the t-stat. Not much modding needed and it comes with the adapter plate replacing the questionable OEM oil cooler.
  16. imspencerwithanr53
    May 27, 2009
    117
    Barista
    Portland, OR
    I installed an Oil Pressure gauge. My car is at home (In college) I will be back on the 10th and will snap a picture when i switch out exhausts.
  17. alden
    alden New Member
    May 27, 2009
    13
    #57 alden, Jun 1, 2009
    Just subscribing to this thread.
    This is good info.
    I was at summit point on may 9th and was hitting temps of 275+ on track and had to back off a bit while running a gear higher to lower the revs.
    I need info on an oil cooler set up that'll be ok for daily driver. Winter here in the DC Metro area can get cold.
    Need to find a set-up before october, I've got 2 days in millville nj. But the sooner the better, that means I can just get back on track sooner.
  18. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #58 Nitrominis, Jun 1, 2009
  19. Nathan
    I'm sorry, I want a LOT more protection than that for the lifeblood of my engine. One good off at the track and I'm leaving a trail of oil and pissing off a lot of other drivers.
  20. mini_racer
    Engr Manager
    Yes, of course it was an oil pressure gauge, you stated that in the previous post. I was wondering what Manufacturer/model did you get. I know the tapless adapter is from CravenSpeed.
    The spring semester should be long done by now, get back home and snap a few pics. :D
