Engine Drivetrain 1st Gen Cooper S Oil Cooler Options
Discussion in 'Tuning and Performance' started by mini_racer, May 12, 2009.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Looking at the type of coolers, it is nice for the cooler to have inlet and oulet, right next to each other as on the cheaper tube in fin coolers. However, there certainly are some efficiency drawbacks to that type of cooler.
    Does anyone have an idea as to what the difference is in oil temp?
    Also, would oil pressure be affected significantly?
  2. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    I would imagine that oil pressure and oil temp would be significantly decreased for a certain amount of time because you are re-routing the oil's path. I am not quite sure of the numbers but once you get the car warmed up the oil pressure will rise again and oil temp will be around 30ºF+ lower than a MINI with no Oil Cooler.
  3. ScottinBend
    OK......just got am email from Moss MINI and you can order just the oil cooler adapter plate from them for $82.50.
    Here is the part number and description.........
    772-158 ADAPTER PLATE, OIL COOLER, S
    This will allow you to put together your own cooler system a lot cheaper than the MADNESS one.
  4. mini_racer
    Engr Manager
    Ok, that is not a bad deal, thanks.
  5. ScottinBend
    I will post a review of it as soon as I get it.
  6. imspencerwithanr53
    May 27, 2009
    117
    Barista
    Portland, OR
    #86 imspencerwithanr53, Jun 4, 2009
    And a how to! :rolleyes::D:cornut:
    edit: I am sure I can do/figure it out myself. I retract the "how to" statement although one would be nice for reference or other members. :)
  7. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #87 Nitrominis, Jun 5, 2009
  8. AllBlack05S
    AllBlack05S New Member
    May 18, 2009
    66
    Selling Harley parts worldwide
    Bartlett, Il
    Yeah Please do. Jan has been pestering me to help him make stuff to put on his car. :D:cornut::lol:
  9. Bimmer Lite
    Bimmer Lite New Member
    English/Journalism teacher and writer
    NJ
    Just some info: I e-mailed Chris at Sneed Speed Shop and asked if his oil cooler would cause problems in cold weather without a thermostat. He said it wouldn't since the system retains the stock heat exchanger.
    - Marc
  10. ScottinBend
    To bad......as that is one main reason to get an aftermarket cooler, replace the potentially problematic OEM oil cooler/exchanger.
    Are you sure? After looking at the website it sure looks like the adapter replaces the OEM exchanger.......?
  11. mini_racer
    Engr Manager
    I think an important point is to remove the OEM exchanger, and I thought that was the consensus as well.
    Agree with ScottinB, it is not possible to keep the OEM exchanger with the Sneed or any other adapter plate.
  12. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #92 Nitrominis, Jun 11, 2009
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #93 Nitrominis, Jun 11, 2009
  14. Bimmer Lite
    NJ
    It's possible that I misinterpreted this comment in an e-mail:
    "The oil cooler will work in the winter because it keeps the stock MINI oil thermostat. I have driven I’m in weather down to about 0F with no problems even cold start outside in the morning."
    It could very well be my mistake - let me know what you think.
    - Marc
  15. mini_racer
    Engr Manager
    #95 mini_racer, Jun 12, 2009
    There is no stock MINI oil t-stat. I think the original response from Sneed was just stated incorrectly.
    The bottom line is that if you live in a colder climate, you may need an oil t-stat to ensure proper minimum oil temps. A pressure and temp gauge would serve to determine if you are within proper min temp levels for the odd frigid morning.
  16. //MZero
    //MZero New Member
    Jun 21, 2009
    9
    I'm in the process of building my own oil cooler, some of you may have heard me mention this on NAM. Thanks to this thread I found out about Moss Mini's adapter plate and ordered it. It was about $100 shipped. I'll take pictures of it after it arrives to show the quality of this piece. I'm really not sure what to expect myself :lol:
    I have also purchased an FC RX7 Oil cooler on ebay. This was one of the details I was leaving out before. Rotary engines are MUCH more sensitive to both water and oil temps and their oil is also put through much more stress. The OEM RX7 cooler is ~ 23"x5"x2.5" quite a heathy sized core, it has a built in thermostat, and can be found pretty cheap. I bought mine for $50 shipped, here is a link to another I was looking at so you can check them out, keep in mind its a ebay link an if it is after July 09' this link probably wont work Ebay
    I plan to somehow redo the bracketry and bolt to the under side of the aluminum bumper, in front of the A/C condenser. Then I'll just have to add lines.
  17. mini_racer
    Engr Manager
    That is a very interesting approach, I think I need to go out to the garage and take a few measurements. :^)
    Do you know what the temp is on the thermostat? From what I have read 220F might be the right open point, not sure exactly though. Anyway, while I like the thermostat being integrated into another component like this is, it would seem better to have it integrated in the adapter plate, I think that would be optimal. Is it possible for the thermostat to get hot enough to open if it is so remote/so far removed from the heat source?
  18. //MZero
    //MZero New Member
    Jun 21, 2009
    9
    Just checking it out, its a 149*F. Click Here 220 would not be an optimal temp for an oil thermostat. 220 is about as high as you want the oil to get, if you can keep it that low. Most say 180 as a good running temp. At 150, the valve is just starting to open at 5mm/min. While it may be a nice feature to have a thermo at the plate...it would be more expensive and complicated.
    It is surely possible for the thermo to get hot enough as remote as it is...it works for OEM's, on cars where oil cooler operation is critical. Should be fine for this application. I'm sure its not going to be as easy as just bolting it on, but I think in the end it will be the best option out there at a much lower price.
  19. mini_racer
    Engr Manager
    Thanks for the link.
    I thought I had read that 225F was the sweet spot for synthethic oil temp and that 180 was way too cool, as it is too thick so you lose power and proper lubrication. Again, this is second hand as I have not researched this yet.
  20. //MZero
    //MZero New Member
    Jun 21, 2009
    9
    Honestly, I'm no oil expert, I'd have to call up an oil company or oil analyst company and ask them. I'll find out and let you know.
