Engine Drivetrain 1st Gen Cooper S Oil Cooler Options
Discussion in 'Tuning and Performance' started by mini_racer, May 12, 2009.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    So, I am guessing you are indicating a measurement at the oil plug, is that right?
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #122 Nitrominis, Jul 19, 2009
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #123 Nitrominis, Jul 19, 2009
  4. mini_racer
    Engr Manager
    Agreed! Wow, everybody is agreeing with you Lynn. :Thumbsup:
    How much difference is there between the pan and a tap placed in line with oil pressure sender such that Craven offers?
    Very simplified the oil is pumped from the pan to the oil filter and is them distributed to the various points of distribution such as the under piston sprayer and head where it drains back to the sump by gravity. I know that under pressure from pump the temp will rise some but it can't be that much since we all know that pumping increases friction therefore raising temps.
    Lynn, you like to all kind of experiments. There is one for you. Install 2 oil temp gauges, one getting a reading from the sump, the other from a combined pressure/temp tap. I'd be willing to ager the difference is less than the tolerance of a mid priced gauge.
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #126 Nitrominis, Jul 19, 2009
  7. Hippie
    Hippie New Member
    Jun 8, 2009
    Good info from Trackpedia & Royal Purple
    Here is what RP had to say about operating temps
    Trackpedia: What is the typical operating temperature for engine oil, and when do I need to consider running an oil cooler?
    Royal Purple: Typical oil operating temperatures in a naturally-aspirated, liquid-cooled vehicle is 220F. For competition vehicles with oil operating temperatures regularly above 220, or for turbo applications not so equipped from the factory, I would recommend running a oil cooler. For every 20 degrees of oil temperature you see beyond 220F, you reduce the life of the oil by half, regardless of brand or base oil type.
  8. mini_racer
    Engr Manager
    Thanks for the link, good to know what the RP experts have to say.
  9. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #129 Nitrominis, Aug 27, 2009
  10. Hippie
    Hippie New Member
    Jun 8, 2009
    and I agree about the optimum temp but I for one was greatful for the info about breaking the 220 mark for temps along with some of the other info posted in the Q&A
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #131 Nitrominis, Aug 27, 2009
  12. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    I know it's been a while but i have wanted to get these photos into this thread for a long time. it's the oil cooler i made for my MINI. works great.
  13. mini_racer
    Engr Manager
    Looks great! Excellent job! How is the clearance with the belt installed, it's got to be close? Also, did you notice a significant difference in the oil temp after install given the same conditions?
  14. Metalman
    7,700
    I would be interested in knowing how it performed through a really cold winter without a in line oil thermostat to reroute the oil. Any concerns with the oil getting too cold and too thick, blocking oil flow to the engine? Or is this a warm weather race car only?
  15. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    it's a warm weather car only, i don't even have street tires for it...lol it doesn't block air flow at all. i run around on the street with a big light bar in front of it and the car never gets hot. on the track i remove it to give more air flow to the W2A and lose a few pounds (and not break a light). the belt has LOTs of room. you can put your whole had between everything. i also hooked the lines to the frame rail to keep everything in place.
    if i did run this in the winter i would use a 0w30 to help flow on start up, but try leaving 5w30 out side and you can see it still flows around a lot. i would not be concerned with it too much unless you have many months at well below 0F, but just switch to 0w30 or get a block warmer as that is better anyways for places that are really cold.
    i don't have any actual temps pre and post, but i can feel a difference when i touch things in the engine bay, and you can see the oil looks better and smells better at the changes. i do a lot of oil changes and you can smell oil that is wasted and look at how dark it is. some day I'll have gauges, but like all of you i am still on a budget...lol
    also keep in mind this car doesn't have AIR anymore.
  16. Metalman
    7,700
    Nice install.
  17. Mike
    Mike New Member
    That's a big deal - much more room to work with without the condenser in place.
    Makes sense for a track-oriented car that's not doing double-duty as a commuter car. Doesn't make sense for my commute into the Mojave desert.
  18. BThayer23
    Do you have (or would you expect) any interference between the oil cooler lines and brake ducts?
    Nice install, too. Thanks for the pics.
  19. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    nope, you would have lots of room for the lines and brake ducts. i plan on adding them some day.
  20. Newbs49
    Newbs49 New Member
    May 23, 2009
    145
    Nice job Chad. Who's cooler core did you use?
