1st Gen R50 Cooper Oil leak from oil filter housing? Cooper 2005
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by nichud23, Feb 12, 2013.
  1. nichud23
    nichud23 New Member
    Feb 12, 2013
    Hi...
    Bought a 2005 mini cooper the other day from a private seller...
    everything seemed fine when i test drived it etc...
    then i go out to drive it today, and notice a massive oil puddle underneath my car :(
    So then I took it to my local garage and they checked for a split O Ring or cracked housing but couldn't find any damage atall...
    It's basically leaked most of it's oil out and now i'm stuck on what to do...
    Anyone have any ideas/suggestions on what the problem could be and how much it's going to cost?
    It had a service in October and they changed the oil filter so it could be over tightened?
    someone help me please!!
    i've only had the mini for like 2 days....
    Thank you :idea: :nonod:
  2. Minidave
    4,592
    Are you sure it was engine oil? Did you pull the dipstick?
    This car has a liquid filled motor mount on the right side, and sometimes they rupture, leaving a big ol puddle of what looks like engine oil on the ground.
  3. BlimeyCabrio
    ^THIS
    The most likely spontaneous fluid event, not immediately following an oil filter change.
  4. SpR
    SpR Banned
    Sep 24, 2013
    64
    12
    work
    michigan
    My car had a leak the other day. I was told it was a bad o ring on the filter.
  5. SpR
    SpR Banned
    Sep 24, 2013
    64
    12
    work
    michigan
    I just changed the oil, im praying it remains dry. This has been the best running car ive ever owned
  6. walshe_ian
    walshe_ian Member
    Dec 18, 2010
    42
    My new o ring broke on me the other day stuck the old one back on sorted :)
    Lube those O-rings when you install them & change them with every filter change. I have seen a few so old that they had turned hard like plastic.
