1st Gen R53 Oil leak.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Apr 24, 2018.
  1. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    big effort difference between dropping the subframe and taking the whole engine out, but I am thinking that at least one of my cars will soon have the engine out, mostly to do the clutch, maybe to do a differential, but mostly to clean everything up.
    It's actually not hard at all, I hear - under 90 minutes if you have a little practice :)
  2. agranger
    With your 3 cars, I think you will have a little practice sooner or later!
  3. MCS02
    That was a good video!
  4. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    I think you've figured it out at this point. But, as confirmation, I had a similar leak and YES it was in fact a leaking timing cover gasket. Its a simple fix, cheap, and you can do it without pulling the motor -- takes longer to pull all the pulleys off than replacing the gasket. The gasket is super small (thin, round) and fits in a grove. I also replaced the oil pump seal rings ( 1 lower and 1 upper) and front main seal. Its all right there in front of you. And, note a few of the cover bolts have small sealing 0-rings. Good luck with that.
  5. MCS02
    @Canusrufis Thanks! I thought it was odd place to have a leak but knowing someone els had the same problem is good confirmation. Good to know its not a hard job.
  6. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    I say pull the engine and build it into a HP machine.. (note I give bad advice....). I pulled the 88M5 engine “because” it had a small oil leak in the back. Striker crank, bigger valves, customs pistons, custom tune and a few years later (long story...:() I think I’m a few weeks from putting it back in. However if calculations are correct, will have considerably more torque, longer power band and will be putting down ~340whp.. We will see...
    So again - build it “while you are there” :D
  7. MCS02
    @Sully I think you give great advice, my wife might not think so but I do! What I need to do is pull the engine and send it to Jan at RMW and get a stroker motor!
  8. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Winner... I would use the "ask for forgiveness" game plan here.
