2nd Gen R56 Cooper S Oil overfill
Discussion in '2nd Generation: 2007+ R55 through R61' started by adamantium, Nov 24, 2013.
  1. adamantium
    adamantium New Member
    Nov 11, 2013
    44
    6
    Hi guys, the turbo seals were redone only,
    I cleaned the charge pipes,the intake manifold,throttle body and intercooler, before I went with a turbo repair(there was oil in all)
    I have no catalytic converter.
    My last two thoughts are a oil soaked/clogged PCV or valve stem seals (although all techs say it can't be - I have a gut it possibly is the seals)
    6,293
    I hope this fixes the problem!
  3. adamantium
    Nov 11, 2013
    44
    6
    What's the you referring to?
  4. adamantium
    Nov 11, 2013
    44
    6
  5. MCS02
    6,293
    Sorry it was late I guess that didn't make sense. I hope the repairs you did solve the problem. As far as the PVC having oil in it, at this point anything it posable. I would check and clean anything I could get to. I know it's been said before but once a large amount of oil gets in the exhaust it takes some time to burn out.
    How much is it smoking now? Also is it using oil?
  6. adamantium
    Nov 11, 2013
    44
    6
    #46 adamantium, Jan 12, 2014
  7. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    If your PCV is not allowing blow by gases to escape into the intake either on the throttle body port or turbo inlet port your crankcase pressure can cause oil to backflow into intake or exhaust. Are you running an OCC?
  8. adamantium
    Nov 11, 2013
    44
    6
    No I'm not running a OCC.
    And from what your saying is that it could be the PCV.
    Is there a test to confirm it? Could I disconnect both the vacuum hose on the left as well as the hose that joins to the turbo inlet while the car is on idle, and blip the throttle to see if the smoke is unchanged?
  9. Metalman
    7,689
    Plug the open hose ends so the engine doesn't go lean, but leave the valve cover connections open and you should be able to run this test...
  10. adamantium
    Nov 11, 2013
    44
    6
    Stupid question, but what should I use to plug it?
    And should I plug and then start the engine? Or do it which the engine running?
  11. adamantium
    Nov 11, 2013
    44
    6
    Thanks for the help :)
  12. Metalman
    7,689
    Rubber stoppers.... Lowe's has them....
    Plug first.... Then start the engine.... If not, you will throw a code for running lean.... The leak will be after the A/F sensor..... Soooo, un-metered air will enter the systen and your ECU won't like that...
  13. adamantium
    Nov 11, 2013
    44
    6
    Awesome man. Thanks
  14. adamantium
    Nov 11, 2013
    44
    6
    Oh and I don't have an A/F sensor.
  15. Metalman
    7,689
    Yes you do.... It's called a MAF (Mass Air Flow sensor).... I just did the A/F sensor as shorthand...
    It determines the air mass going to the engine so the ECU knows how much fuel to add at the cylinders adjusted by input from the O2 sensors....
    Any leaks to this measuring system show up and the ECU attempts to compensate.... Which is where the stoppers come in....
  16. adamantium
    Nov 11, 2013
    44
    6
    I swear I don't lol. I know what a MAF is, but I know some minis don't. I am from South Africa, I'm sure ours didn't come with it.
    From the filter box, down to the turbo inlet there is no MAF :)
  17. Metalman
    7,689
    Sooo you are saying you don't have #13?
    Well...... Somewhere your ECU determines the proper fuel ratio to run the engine even in
    South Africa...
    You have two choices.... Pull the hose ends off the valve cover and plug the hoses themselves.....
    Don't plug the hose ends and you will probably introduce non metered air and generate a CEL.... with a lot of engine stumbling....
    Hose plugs are cheap and you don't need to deal with throwing a code...
    Your choice....
  18. Metalman
    7,689
    So you have this....
    Then the small hose on #10 might suck in dust......
    The other hose on the valve cover goes down to the throttle body on the intake.... I'd suggest you plug that one then and run you test...
  19. Metalman
    7,689
    Plug the hose end by the #1
  20. adamantium
    Nov 11, 2013
    44
    6
    Wow, thanks so much for the detailed response!
    Yes mine is exactly like the bottom pic (no MAF)
    Will attempt it in the morning, as per your initial instruction.
