2nd Gen JCW OK this is weird.... Now I'm confused....
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Mar 17, 2013.
  1. Metalman
    Soooo... I did an oil change this morning....
    I'm under the MINI.... And I notice this big red sticker on the manual transmission case.....
    According to the MINI Operating Fluids Information sheet...
    Without limited slip differential
    I should use 83 22 0 421 925 MTF LT-4 Extended Life Fluid
    This is also confirmed by the Bentley manual....
    For those with the Limited Slip Differential
    I should use 83 22 0 403 247 MTF94 Extended Life Fluid
    My window sticker says I have the E-diff...
    Is it possible the MINI worker slipped a manual trans with the LSD already installed during my build?
    How should I test this to verify one over the other?
  2. Jason Montague
    :cornut: You're over my head but GOOD LUCK MM.:Thumbsup:
    If you have the real LSD thank your lucky stars. Leave me your car & in week or two I'll have the answer for you.
  4. Metalman
    HaHaHaHa....
    Yeah.... I either got a great deal from a careless assembly worker slipping me a free LSD....:fingerscrossed:
    OR
    I got a great deal from a careless assembly worker slipping me a free red sticker....:lol:
  5. Metalman
    Soooo.... Jack both wheels off the ground....
    Spin the wheels by hand...
    If they turn in the opposite direction.... Not Limited Slip
    If they both turn in the same direction.... Well it's not just a red sticker then is it.....
  6. old81
    1,542
  7. Justa Jim
    ^^^ What he said....AND?
    I can't fill you in. Chuck hasn't dropped the MINI off to me yet. :D
  9. Metalman
    AND I'm home now....
    Won't get to test this until next weekend...
    To be continued.....:D
  10. cooperjet
    cooperjet Well-Known Member
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    The suspense is killing me!
  11. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Boooooooooo...:D
  12. Metalman
    #12 Metalman, Mar 18, 2013
    Anyone notice there is no salt corrosion on my 2009 transmission case....:D
    This baby sleeps in a nice comfy garage during the nasty OHIO "Salty" time....:arf:
  13. ScottinBend
    That may be......but it's still not an R53.
    :biggrin5:
  14. Metalman
    You'll have moar fodder when the 3rd Gen's come out...:D
  15. peep
    peep New Member
    Jan 29, 2013
    281
    82
    Central New Jersey
    me too !!!
  16. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    642
    652
    Oracle DBA
    Skokie Ill
    I thought the test was a quick burnout..
    2 stripes = LSD, 1 stripe = not
  17. mrntd
    If you're home and the car is home then........
  18. Jason Montague
    :cornut: I think that our legs are being pulled:Thumbsup:
