Olivia:The Mental 1.8L C38 Rotrex Elf Army
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Sleek Motoring, Mar 1, 2015.
  1. cct1
    Everyone needs a hobby...
  2. TheModFather
    Business picked up once the beard came in... Maybe it covers up just enough of the ugly to get a quarter! :D
  3. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    Shiittt...I thought dimes were good!:mad2:
  4. Sleek Motoring
    Dec 7, 2014
    249
    143
    Lets get this tread back on topic.
    One of the major shortcomings of the Mini is its fuel system. With the help of knowledgeable people we have come up with a high HP setup that will handle E85 fuel.
    I am going to remove the stock fuel pump assembly and leave the sending unit in the passenger side of the fuel tank to retain the stock fuel gauge.
    I will be adding sumps for each side of the "saddle tank" lobes. I have a 700hp Ford 6.0 turbo diesel that I borrowed the idea from when I upgraded the fuel system in that.
    Sumps
    Sumps
    A fuelab 41401 Prodigy external pump will be controlled by the Vipec ECU. A 75 micron pre filter and a 40 micron post filter will be used to catch any contaminates floating around in the tank.
    Pump
    Fuel filter
    Tying the whole system together with Fragola -6 braided racing hose and a fuel regulator. I will also be running a return line; splitting it with a Y-fitting feeding both tank lobes with bulkhead fittings in the top of the tank. Stainless braided line will be used around the tank to prevent any rubbing through.
    Nylon braided line
    Y-fittings to tie both sumps together and the return line.
    Bulkhead fittings for return.
  5. RallyMini370
    Will the pumps hang down below the tank?
  6. Sleek Motoring
    Dec 7, 2014
    249
    143
    A sneak peak of the powdercoated bits! Enjoy!
    GP trailing arms!
    Control Arms!
  7. Sleek Motoring
    Dec 7, 2014
    249
    143
    I haven't figured out where I am going to mount everything yet. I put my order in for everything today. I will start mocking it up as all the pieces come in! I am fully documenting everything so I will definitely keep you posted!
  8. RallyMini370
    That powdercoat looks good...would last about 10 minutes on my Mini
  9. Sleek Motoring
    Dec 7, 2014
    249
    143
    Quick update:
    Just got my Supersprint header and race cat back from getting ceramic coating. The coating is “White lightening” from Swain Tech. It is a true ceramic heat insulating coating. It is rough and porous feeling just like a ceramic pot with a thickness around .015”.
    I’ve used this coating in a few different applications with surprising results. I coated my diesel truck’s complete exhaust system from the headers, up-pipes ,turbo, downpipe to the middle of the exhaust down the truck. I’ve seen 350-400 degree drop in surface temperatures on the pipes themselves with my truck. It helped immensely to diminish the under-hood temps. Keeping the heat inside the pipes I saw a dramatic decrease in turbo lag due to increase drive pressure on the turbo!
    I am hoping in this application to:
    -Reduce under hood parasitic heat transfer.
    - Increase the scavenging affect:
    After heat has performed its function in the combustion chamber, it travels out the exhaust port and into the exhaust header or manifold. If the gases are allowed to cool they lose velocity and the scavenging effect is reduced. By insulating the exhaust system, gases inside are kept at the highest possible temperature resulting in greater exhaust gas velocity and higher efficiency.
    I will be fastening the header down with a set of Stage 8 locking manifold bolts!
    Supersprint Header and race cat:
    Stage 8 locking fasteners
  10. Sleek Motoring
    Dec 7, 2014
    249
    143
    Time lapse video of the disassembly process. The engine is currently being built as I type this. The engine was sleeved and ready for final honing last week. It will return as a fully built 1.8L Stroker engine.
    Enjoy the video!
    [ame="https://www.youtube.com/watch?v=tJj9Uw-x_UA"]Time Lapse-MINI Cooper S R53 Engine removal:1.8L stroker engine build - YouTube[/ame]
    Sleeves in the engine! Ready for final honing!
  11. RallyMini370
    I think if you speeded me up working on the Mini in CR the speed would look normal..LOL
  12. TheModFather
    Do a time lapse of my build, and it still makes snails look fast! :(
  13. Sleek Motoring
    Dec 7, 2014
    249
    143
    What are you talking about? The video was at normal speed...:crazy:
  14. llabmik2
    llabmik2 New Member
    May 11, 2012
    34
    20
    Fruita, Colorado
    E85 with Vipec Flexfuel FTW!!!!
  15. TheModFather
    Wholly crap! Youre back! :)
  16. llabmik2
    llabmik2 New Member
    May 11, 2012
    34
    20
    Fruita, Colorado
    Looks like it. Have to "be nice" I guess.
  17. Dave.0
    Welcome back. :Thumbsup:
  18. llabmik2
    llabmik2 New Member
    May 11, 2012
    34
    20
    Fruita, Colorado
    Well thanks Dave!
  19. TheModFather
    Good to have another real tuner here! If we keep this up, M/A will be the only forum where the power comes from! :)
  20. llabmik2
    llabmik2 New Member
    May 11, 2012
    34
    20
    Fruita, Colorado
    I thought that was the RMW forum
