One week old Mini owner with Supercharger issues...
Discussion in 'Starting Line - New Member Introductions' started by 2003Mini S, Sep 27, 2016.
  1. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
  2. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    Any members in Las Vegas area by any chance?
  3. 00Mini
    Save your money and keep your stock coil and wires. They will more than handle your your planned mods.
  4. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    00Mini.....Do you have any mods on yours? Stick or auto?
  5. ZippyNH
    87 octane won't kill a sc....but it does make the valves run hot...then because they have been overtemped, they are soft, and wear... result, is the car starts to have a misfire....and worsens rapidly as the valves wear, and they sometimes can break....in a 1000 miles or so, the car is underivable, and the head needs to be removed for a valve job....one tank is likely ok...some folks do it LONGER....but many of us carried a bottle of octane boost if we needed fuel in a location that only had mid or low grade....
    If your pulley has Allen head bolt holes, it's aftermarket.
    So you likly have a 15, 16, or 17% reduction....it usually has the % engraved on it, and a brand name.
    You can save the old pulley you have and put it on the new SC....
    You MAY need to use some heat to remove the bolts...they are usually installed with a bit of lock-tite, and the heat will soften it...the Allen headed bolts will be VERY tight if done right...tighter than the size of the bolts indicate.
    +1 on the stick coil and wires...they are fine for most...just check the plugs on the coil...it has nickle plated iron plugs...and corrode quickly...a bit of sandpaper and some dielectric grease will fix the issue if the coil is good....the wires are very short...so can last a long time if good, but you can get decent replacements pretty cheap.
  6. 00Mini
    Bone stock '03 MCS stick that is need of some tlc. I have some pieces parts on hand and like you I'm going to need a supercharger.
  7. Dave.0
    I have an 05 JCW and it puts down over 250 hp at the wheels and I only use OEM coil and wires.
    I also know race MINI's that make over 400 hp and they still use the OEM coil and wires.
  8. MCS02
    Use only the stock coil and only 93 octain if you can get it 91 is ok if that is all you can get. I have a 17% pulley but I would get a 15%. You will need colder plunges Detrout Tuned can set you up with those also.
  9. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    Thanks for the money saving pointer......
  10. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    I watched few video's on you-tube on removing SC for service reasons.....which is same thing as replacement steps......No video on reinstalling steps......
    I know it is a stupid question...... Any pointers or things I should know as far as reinstalling goes?
    What do you think of K&N replacement air filters? are they worth the money or should I just buy a cold air intake? I guess I have a after market pulley already....:)
  11. ZippyNH
    A panel filter will help you a bit...the CAI does add some NICE sc whine....enough you might not need the exaust (was too much $$ for the gain per hp in my case, so I waited 10 years for the stock unit to rust out....the sold the car, stocker still in good shape)....just pick you cai based a bit on usage...
    The typical unboxed cone filter, an alta clone is OK...but can be slightly loud at some rpms on a long highway trip...used jcw and Dinian ones a a bit more sedate...good for some, not others. There are some other nice options....but $$ goes up rapidly....but imo the 3 mods every r53 should have are a cai, a pulley, and a bigger rear sway bar....
  12. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    Saw this on ebay......Life time warranty
    on supercharger!
    What do you guys think....anyone ever heard of these guys?
    [ame="http://www.ebay.com/itm/201678169221?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT"]Fully Rebuilt Factory Mini Cooper s 02 07 supercharger with Lifetime Warranty | eBay[/ame]
    just if cut and pasting the link does not work....item number is 201678169221
  13. MCS02
    I think, go with DT for the SC. As far as a CAI goes I have one with a K&M cone filter. You want it to be a fully inclosed box so it does not suck in hot air from the engine bay. I cut a hole in the plastic at the back of the box that leads in to the area under the grill at the front windshield. When I push it to the redline I and anyone els near by can hear the supercharger scream. On the highway I really don't hear it so it is no problem on trips on the highway at speed, and I know the engine is getting plenty of cold air.
  14. ZippyNH
    Do what you feel us right...the same seller has multiple mini sc listed at different prices and warrentys....some say one year, premium parts, etc...so lots of variability....seems to be a rebuilder based in Florida...
    The year on the post is wrong...should be 02-08 to cover the cabrio....my experience opinion with eBay...bay cheap junk...big items can be a big issue imo, but do what you feel is right for your $ situation .
  15. Nathan
    MSD Coil is a waste of money, anecdotal reports are out that that MSD coils have messed with the ECU. The coil from MSD is for the Neon version of the engine, the hardware doesn't fit. Why bother...
    As to that ebay SC. Who's lifetime? Who rebuilt it? Is the savings of a few bucks worth all the potential issues of a hastily rebuilt SC? What is known about that entity selling it?
    The joy of low price is quickly dashed to nightmares by the pain of poor service and quality.
  16. Dave.0
    Looks like crap to me as the rotors are not even coated.
    You do not want to go cheap on this part. Call Chad at Detroit Tuned and get quality parts the first time.
    I always hear people say I can't afford that part but in the end you will buy the right part and pay for the labor twice.
  17. 00Mini
    ^^^^ Very sound advice.
  18. Metalman
    Good luck trying to deal with an ebay internet business in vaporland....
    Detroit Tuned has a real brick and mortar building.... He can't hide...
    Chad and his people are great to deal with...
    Chad is an active member on White Roof Radio...
    DT is a forum supporter...
    Chad has a reputation to maintain...
    Don't buy stuff from Florida.... That place is just plain weird...
  19. DneprDave
    That's good to know that Delirium Tremens is a MA supporter.:biggrin5:
  20. 2003Mini S
    2003Mini S Member
    Sep 26, 2016
    36
    I appreciate your feed back and definitely your's and other members opinions....
    I did also notice different prices and warranties....I think Detroit is who I am gonna go with despite being few hundred more....I am sure in long run it will pay for it's self!
    Thanks
