Engine Drivetrain 1st Gen Cooper S Oops - I did it Again. Gnat Done Blown Up
Discussion in 'Tuning and Performance' started by Nathan, May 1, 2015.
  1. BlimeyCabrio
    I would wager the plug had NOTHING to do with the failure.
    ^^^ Yes a symptom not a cause.....
    #24 Nathan, May 4, 2015
  4. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Good luck getting Gnat all fixed up!
    By the way, the spark plug you want for the rebuild is NGK BKR7EIX (aka #2667). Coincidentally the same plug I ran in the Exige S, and in the turbo Miata.
    Loaded on trailer at MOTD. I was told it is a good thing I happened by after it was loaded. The car would not start at all. Chad hopped in, rolled it downhill and onto the trailer in one swoop. The crowd applauded at The Chad's skill.
    Safely in MI at Detroit Tuned.
  6. Dave.0
    Multi point plugs suck on higher powered MINIs with larger CAMs, BVH and larger Injectors 550's . Remember Nate's care in not OEM anymore. Hell it does not even have am OEM ECU. The high heat and multi spark point plugs cause issues and burn up and that is absolutely caused this issue along with the below. The plugs WERE 1/2 the problem.
    The other half was the basic tune put on the ViPEC just so Nate could to get it back to Ohio last year. Remember his Myne's tune on the Byte-me-tronic bricked his ECU and he had to get a ViPEC to get the car running again.....? Those plugs were from the Byte-me-tronic Full Access Tune crap.
    I can see how Nathan my have forgot about the plugs and addition needed. I mean after Nate got home last year he took a MINI vacation at a local hospital after he bricked his heart and had to do cardio rehab. Then the drunk driver hit his car in the middle of the night. Things and tasks and life gets backed up or put on hold but our M\A was sent out on time. :D
    So I guess he forgot to have his plugs changed to single prong NGK's and connect with Jan to finish fine tuning his ViPEC so he could full out romp on his car. Looks like Nate's RMW BVH Serial #2 will need to go back to Cali to have the valve seats replaced all valves checked because I bet 1 if not both are bent in the cylinder the plug failed when the ceramic around the center electrode broke and fell into the cylinder and bounced around until it was spit out the exhaust port via the exhaust valve.
    Oh it will also be good to have it flow tested again since you in this deep you may as will do it right once rather than going through the process again if a step is skipped.
    Oh FYI it still looks clean Nathan, that guy looks like he did an Awesome Job. :Thumbsup::rolleyes5:
  7. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    What happened to the wheels that were on the Gnat last year?
    I would normally change plugs in my spring maintenance. I did forget. Even have a box of the BKR7EIX plugs on the shelf.
    This was totally my fault.
    Between the bricked heart, subsequent broken ribs and all the carp floating round in my head I just plum forgot to take the plugs to Best Motors Werks.
  9. Dave.0
    Those are Chads race car wheels, since it was going to be on a trailer going back to Detroit Chad put Nathans wheels on his race car to drive it back to Detroit.
    Wheel Swap.
  10. Nathan
    Tire swap so Chad's dad could drive back the Detroit Tuned MINI.
    The black wheels on Gnat currently are Chad's super sticky tires.
  11. Jason Montague
    I think that Nathan only does R53s but it gave me a good laugh any way which I think was your point.
  12. rkw
    rkw Well-Known Member
    443
  13. Jason Montague
    #34 Jason Montague, May 5, 2015
  14. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    My rear main started leaking badly once i got to the D...so i have lots of cars to fix!
  15. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    ....Just needs a regap.
  16. Dave.0
    I ignore all Ford Focus Ooops MINI F56 comments on principle because you all know my feelings and out of respect for Nathan I will not post them.
  17. Nathan
    On the trailer headed to Detroit...
  18. Jason Montague
    Hey Dave.O old buddy, 'splain on me Ford Focus F56 please(in a PM if need be ).
  19. cct1
    That really doesn't need an explanation....
