1st Gen R53 Cooper S Outside Air AC Intake Location
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by wzabrouski, Aug 12, 2011.
  1. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    Which cowl vent has the outside air intake for the AC system? Got some cleaner to try and get rid of the odor and I am not sure if it is on the passenger or drivers side cowl vent.
  2. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Not sure, but have you changed the cabin filter (underneath the dash on passenger side)?
  3. Metalman
    If you haven't, wear hazmat gloves when you do.... You will be surprised by what you find.
  4. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    The intake is inside the pass cowl area. It is waaay down towards the bottom of that cavity.
  5. HRM
    HRM New Member
    Mar 16, 2011
    74
    10
    Mold odor can be a blocked plug for the condensation. From under the car you can find a rectangular tube that needs to be checked. Water should drip freely out of there.
    First the filter needs changing. They get really nasty fast and if never changed it often is actually scary looking.
  6. wzabrouski
    32
    Executive Director
    Keller, TX
    Changes the cabin filter last week. Will check the drain. Thanks
  7. DneprDave
    I have Gen 2, but I found a squirrel's nest in mine, after only a few months. It's a good thing to check regularly.
    Dave
