2nd Gen R56 Cooper S Overtemp warning in 20 degree weather?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Zapski, Nov 13, 2013.
  1. Zapski
    Ok, this is a bit worrisome. After about 10 miles of highway driving at just above the speed limit (being honest here, about 72mph) I got an temperature warning. The outside temperature was about 28 according to the dash.
    Slowing down a little and coasting made it go away, and it didn't come back on the road part of my commute, though I did keep revs below 3000.
    Any quick thoughts? It's an 08 MCS.
    Check the coolant level.
  3. Minidave
    And make sure your antifreeze is good, your thermostat could have frozen.
  4. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Temp sensor going bad? They can give false readings....
  5. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    I had this happen to me at about minus 20 degrees in my Rabbit GTI - turned out the lower radiator hose had shrunken away from the lower radiator fitting in the cold and was leaking.
  6. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    Check water pumps for leakage if your coolant is low. Don't take time getting it fixed if it gets too hot it doesn't take any time at all to blow the head gasket possibly warp the head. (Been there done that and now I'm on my second motor in my 08 MCS)
  7. Dave.0
    ^^^^ all the above should help you find the problem.
  8. Zapski
    Coolant was lower than the min, so I added some distilled water and am taking her in next week.
    Thanks, guys! :Thumbsup:
    My money is on a leaking thermostat housing.
  10. Zapski
    Took it in this morning, and that was exactly it. Nice guess! :Thumbsup:
  11. Dave.0
    It was no guess as most of us have replaced the thermostat housing at least 2 times or more.
    Glad everything is fixed now. :Thumbsup:
    Very glad it worked out for you. Warranty repair FTW!!! :Thumbsup:
  13. Dave.0
    Warranty repairs is one of the few good things the Stealership offer and only because they have too.
