Make sure that the system is bled.
All work was done few thousand miles ago with no problems....I will make sure no air has gotten in there,
Thanks -
Reset the adaptations, and delete faults. If you are using a lower temp thermostat and making only short trips that will cause it too. If the engine doesn't get up to the temp the dme wants to see for a specific amount of time it will throw that code
Sent from my Nexus 6 using Tapatalk
