R53 P2096 Error Code
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by krushmoto, Sep 24, 2018.
  1. krushmoto
    krushmoto New Member
    May 17, 2015
    Hi all,
    I searched for the error code but haven't found anything recent and also had a few questions so I started this thread. Wasn't sure if I should reply to an old thread or start a new one. Forgive me if I'm supposed to just reply to the old thread.
    Anyway I've had a P2096 for the past few months. Checked it on an ODBII scan tool and figured it was the O2 sensor. I replaced both and my mechanic reset the code and it all was fine. I drive away happy. Fast forward I start the car and the light is back. I use my scan tool and it's the same P2096. I check the O2 sensors and bank 1 is bouncing up and down while bank 2 is steady.
    Is bank 1 supposed to bounce up and down at idle? When I give it gas it steady's up.
    Now I read that P2096 is a hard code. How can I tell if it's triggering b/c the fault is still there or b/c the code is still in the computer?
    BTW my inspection is up at the end of the month so I'm suddenly pressed for time! DAMN IT!!!
    Thanks.
    #2 Dave.0, Sep 24, 2018
    It was your O2 and since those are replaced you need a BMW scan tool to clear the hard code stored in the ROM.
    Your local MINI dealership can do it for you for a fee.
    A typical scanner / code reader will not do it.
    You cou;d also buy the BavTech cable in the link below for $179.00 and connect your car via a Windows laptop with the downloadable BavTech software.
    Hint: do not register your VIN to the software and you can use this cable on several cars.
    I had this cable and software when I still had a factory ECU and it is an excellent tool and worth the money. I sold it in the Spring when I upgraded to a ViPEC / Link ECU.
    http://www.bavariantechnic.com/buy.aspx
    • Like Like x 3
    • Informative Informative x 1
  3. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    The Bavtech device is the bomb. Well worth it f you plan on keeping the car. And, 2096 code can be from intake or exhaust leak so be prepared to dig a bit more if it comes back once cleared.
    • Like Like x 3
