parting out my 5 speed r50 all the new parts i put on altanator waterpump tesioner pully and bracket brakes f+b ceramic drilled and sloted rotors f+b both rear calipers all ebrake cables front and rear crank seals tranny main seal both cv shaft seals thermostat with gasket thermostat housing and gasket temp sensor clutch,presure plate and throwout bearing fidanza light weight flywheel clutch fork bushings coil plugs wires both front lower ball joints ss braded f+r brakelines front motor mount oil filter housing gasket quick hitch from mini fini gas cap serpinteen belt let me know what you want and ill remove for you
