1st Gen R53 Cooper S Parts to Replace During Clutch Job
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by SooperCoopers, Apr 24, 2016.
  1. SooperCoopers
    SooperCoopers New Member
    Feb 12, 2013
    23
    9
    Hello everyone,
    I am planning to do another clutch job (with single mass flywheel, new flywheel bolts, throw out bearing of course) in about two weeks, and I would like some advice as to which parts I should replace while doing this...
    Here is what I have thought of so far:
    Input Shaft Seal
    Rear Main Seal
    Clutch Fork Bushings
    Throw Out Bearing Guide tube (necessary?)
    Axle Shaft Seal
    Anything I am missing, or really dont need above? I just want to tackle all of the relatively cheap stuff while I have the bell housing off to maximize the efficiency of this project
    Also, I saw this gearbox seal rebuild kit on Ebay, and was curious if anyone has had experience with this? Would anyone recommend buying this kit?
    Mini Cooper s R5 R52 R53 GS6 85 Gearbox Bearing Oil Seal Rebuild Kit | eBay
    Thanks for your help!
  2. ScottinBend
  3. Minidave
    4,592
    I'm of the "if it ain't broke, don't fix it" train of mind, that said if the box has 300K on it maybe that's a different story. Point being, unless it's leaking I leave it alone. New fluid and off she goes (once the clutch is in of course)
    What about the power steering pump and lower control arm bushings while the subframe's down?
  4. MCS02
    Is see rainbows..........no I have no LSD sorry
  5. SooperCoopers
    Feb 12, 2013
    23
    9
    Well originally, I was going to put in another clutch since I thought I had a bad Input shaft seal...so I wanted to kill 2 birds with one stone.
    As it turns out, I have an axle seal leak instead, a much easier fix. I confirmed this with a UV tracer dye. Phew :)
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
