1. DneprDave
    I got this off of another list, I thought I should share it here.
    Machinist's Workshop Magazine (March/April or May/June, 2007) actually tested penetrants for break out torque on rusted nuts. Significant results!
    They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
    *Penetrating oil .......... Average load*
    None ..................... 516 pounds
    WD-40 .................... 238 pounds
    PB Blaster ............... 214 pounds
    Liquid Wrench .......... 127 pounds
    Kano Kroil .............. 106 pounds
    ATF-Acetone mix.........53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
    • Informative Informative x 1
  2. gjxj
    gjxj Member
    Jun 16, 2015
    32
    11
    thanks. In case its not obvious the acetone mix is probably more damaging to paint, plastic bits, etc. Maybe you want to reserve that for really tough situations.
    I'm rather surprised pb blaster did so poorly. Was it the original penetrating catalyst stuff? They sell a whole line of different lubes now.
  3. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    Sure.... now you post this....after all my stuff is back together....:lol:
    Thanks for this, it will definitely effect what I use next.
  4. Minidave
    The other problem with the acetone mix is that it separates out over time, and the acetone evaporates.
    I use Kroil.......it works.:Thumbsup:
  5. DneprDave
    Just mix the ATF and acetone as needed.
    Something else I've used for years as a rusty nut release, is beeswax. I heat the nut with a torch just hot enough that the beeswax melts and wicks into the joint between the nut and bolt or stud. Candle wax works pretty well also. All the ships I've worked on have beeswax in the shop for just this purpose.
    Aero Kroil FTW! Over the years I've used many types & the Kroil is the best so far for this old wrench twister.
  7. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    Penetrating oil? Ummmm, KY?
    Sorry, I couldn't resist. I'll go back to my gutter, now. :blush2: :frown2:
    CD
  8. Minidave
    #8 Minidave, Nov 12, 2016
    I have used wax as well, particularly on exhaust fasteners, where it doesn't matter if you get them hot with the torch, but then I always wonder if it was the wax or the heat from the torch that did it!
    Nah, you don't have to get it that hot with the wax for it to work.
    CRC makes a product that works really well too, that freezes the parts and lets them release- pretty amazing stuff actually.
    What you are describing is called wiener slip. :devil:
  10. 00Mini
    2,266
    I have used kroil and know it works well but had never heard of mixing atf and acetone. PB Blaster kinda surprises me and just recently heard of the wax trick but haven't had the opportunity to use yet.
  11. InstrumentOfPeace
    InstrumentOfPeace Active Member
    Jan 10, 2020
    106
    69
    Just adding muriatic acid into the mix.
    Just be sure to use it in a well ventilated area (i.e. outside only)
  12. agranger
    I saw someone do a YouTube video like this and the ATF mix did well there as well.
  13. Dave.0
    Birthday cake candle wax is awesome to use on the inside of metal valve stem caps that tend to get stuck.
  14. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,705
    924
    physician
    York, Pa
    Does it keep brass or steel caps from
    welding themselves to aluminum (TPMS
    sensor) stems if you leave them on too
    long between checks?
  15. Dave.0
    Yup
    I was told by the local tire shop that I use & trust to never ever put metal caps on the TPMS valve stems. He said they often weld on due to corrosion. Plastic caps for this guy.
    Almost forgot. Happy Birthday Dave!
  17. ScottinBend
    Dave has birthdays?
    o_O:):)
    • Like Like x 1
    • Funny Funny x 1
  18. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    I thought we stop counting past 2 digits? :||
  19. agranger
    Found some for you!
    I'm tempted to order a bunch of these and apply 'em to any uncapped valve stems I come across at my next MINI event. :D
    • Funny Funny x 3
    • Winner Winner x 2
    Oh dear God! Do those come with matching truck nuts? ;)
    • Funny Funny x 3
    • Winner Winner x 1
