Engine Drivetrain 1st Gen Cooper S Plug wires
Discussion in 'Tuning and Performance' started by S curvz, May 2, 2011.
  1. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    I am looking to replace my plug wires as part of my tune up. I currently have the fireblade wires. When I changed over to these from stock I didn't notice any difference in performance. I was curious if I should get OEM, another set of fireblades or another brand all together. Also, what is the recommend change interval for the coil pack?
    Thanks
    OEM work just fine even on heavily modded engines. For a bit of color other brands such as Kingsbourne work well too. There is no need to get any sort of expensive super fancy brand of wires.
    I have no idea on the coil pack as I've never had an OEM one go bad, only an MSD one.
    As Nathan says & I wholeheartedly agree stock wires are fine. Nothing wrong with the fancy ones if you want a bit of engine bay bling. Replace the coil when it carps out. If it works fine now save your money.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    +1 on what Nathan said about wires. I only switched to aftermarket wires because I wanted red wires instead of black.
    The only issue I know of with the OEM coil is that sometimes the contacts corrode.
    When you change out the wires clean the contacts on the coil pack if needed & put some dielectric silicone grease on.
  6. ScottinBend
    That damn number three coil contact still corroded on me even with the dielectric grease on it and cleaning it regularly. That's why I replaced it with the MSD one. So far no problems......
    Been running the Kingbourne wires since the coil change out cause I wanted the colors to match.......:D
  7. S curvz
    S curvz Member
    Oct 31, 2010
    178
    16
    Thanks guys. Gonna try and stop by my favorite local supply shop for factory wires. I have blingy ones now, they get lost as it is.
