Pot hole warning 81South
Discussion in 'MINIs on the Dragon 10 (May 2 - 6, 2012) - TN / NC' started by Tigger, Apr 28, 2012.
  1. Tigger
    Tigger New Member
    Nov 10, 2009
    253
    52
    Alexandria, VA
    Some friends of ours were driving down this morning and hit a pretty severe pot hole on 81South at around mile marker 115. It got them a tow to Flow MINI, I think the rim was damaged.
    If you're coming through that way, please be on the look out around mile marker 115. I think it was the left lane, not 100% sure.
    Ali
  2. maacodale
    maacodale Club Coordinator
    255
    Poquoson, VA
    Ali, is that in Virginia or the North Carolina part of I-81?
  3. Dave.0
    I am thinking VA since that is the longest part of 81S. Also the mile markers reset when you go from state to state and I don't think NC has that much of 81.
    Could be wrong.
  4. motodad307
    motodad307 New Member
    Oct 10, 2010
    69
    22
    Paris, Ohio
    NC has no 81.
  5. Tigger
    Tigger New Member
    Nov 10, 2009
    253
    52
    Alexandria, VA
    They didn't say, I passed on all I had. I'll see if I can find out. I know they got towed to Flow MINI, don't know if that helps.
    The rim was bent up pretty bad, but they are back on the road now.
  6. Dave.0
    Thanks I forgot about that. (Duh)
  7. Justa Jim
    Tigger, where were they in regards to towns? Harrinsonburg, Staunton, Roanoke, Salem (VA), Bristol, Johnston City (TN).
  8. Tigger
    Tigger New Member
    Nov 10, 2009
    253
    52
    Alexandria, VA
    I'm going off of text messages and facebook posts to try and figure it out.
    I found one picture of the tow truck and googled the phone number, the truck was from Wytheville, VA.
    That's all I've got
  9. Tigger
    Tigger New Member
    Nov 10, 2009
    253
    52
    Alexandria, VA
    VA 81 S near mm 116. Avoid the left lane. It's where they are doing blasting/construction work.
  10. minimark
    Thanks for the heads up!!
  11. Justa Jim
    Thanks, that helps a lot. That would be below Roanoke and they have been blasting there the last two years. Good to know.
  12. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Definitely something to pay attention to - pass along thanks for the heads up.
  13. KittyMini
    KittyMini Club Coordinator
    1,183
  14. 804 mini
    804 mini New Member
    Apr 30, 2012
    118 is Christiansburg/Blacksburg area, when you see that shoulders are blocked off with concrete barriers be on the lookout.
  15. smurfette26
    smurfette26 Club Coordinator
    Nov 1, 2010
    109
    Thanks for the info,that is right around where we will stop so likely dark when we will be around that area. We will try to remember to extra cautious.
    Glad the friends are back on track!
  16. carman63
    carman63 Member
    Oct 14, 2010
    123
    17
    Purcellville, VA
    Hi guys,
    My wife and I found that pothole for ya, so no need to re-discover it :cornut: Christiansburg sounds like the area we stopped and assessed damages. We drove as far as Polaski before TPMS went off. MINI Roadside picked up the tab for a tow to Flow MINI in Winston-Salem. We called ahead to make sure they had a wheel and tire (check, and check) and to make sure they'd still be open when we got there (check). They were waiting on us when we arrived, and had us back on the road in short order. No alignment issues, no mushroomed strut towers, no other problems except for a lighter wallet :arf:
    -Jim
  17. Justa Jim
    Glad it worked out well in the end. Hopefully they have fixed it by now. :fingerscrossed:
